Yes, the centre will almost definatly fit.
You will probably need new side carrier bearings though as the later hilux's had larger id bearings (50mm compared to 45mm).
Pull the centre apart and sandblast the metal disks in the clutch pack and shim it up as per normal. Doing this will cause the material to wear quicker and cause the oil to require changing more frequently though.
				 Another Hilux LSD thread
