Results 1 to 3 of 3
Thread: Another Hilux LSD thread
    May 2012
    south australia
    Default Another Hilux LSD thread
    Guys, just need a simple answer. I have a 4.33 centre out of a 70/80's Hiace in my car. Welded into a spool. Ive found a LSD centre, (no carrier or pinion/crown gears).
    Its out of a 2001 hilux, would this LSD bolt into my carrier using my gear set with a minimum of fuss, ie just set up using the standard parts.
    Also, I know these LSD are renowned for happy wheeling, does any body make upgraded washers that can be put into it it make it nicer/last longer. Getting a stronger spring or shimming them is easy enough, but surely someone has a better washer design out there?
    Thanx guys
    Dec 2011
    Default Re: Another Hilux LSD thread
    Yes, the centre will almost definatly fit.
    You will probably need new side carrier bearings though as the later hilux's had larger id bearings (50mm compared to 45mm).
    Pull the centre apart and sandblast the metal disks in the clutch pack and shim it up as per normal. Doing this will cause the material to wear quicker and cause the oil to require changing more frequently though.
    TA23 Celica Convertable *Needs Paint*
    HZJ80 Landcruiser - For driving over Hondas
    May 2012
    south australia
    Thanx for that reply, Ive got the LSD appart and will be blasting the smooth disks in the morning.
    In regards to shimming, do I just add the factory Toyota ones? Un fortunately I cant bench test the centre cos I don't have any spare axles. Id hate to make it so tight I break something or make it a locker.
    Surely there must be a toyota spec on what to check to bring them up to factory spec
  1. Replies: 1
    Last Post: 06-08-2011, 12:44 PM
  2. "I found this thread and it should be locked" thread
    By 74sLeeka in forum Toymods Car Club Membership and Feedback
    Last Post: 21-01-2008, 11:52 AM
  3. information on 1GGTE into RA23, hilux,crown,carona pug brake upgrade, hilux diff.
    By celica77 in forum Engine & Driveline Conversions
    Last Post: 15-05-2007, 11:14 AM
