Results 16 to 23 of 23
Thread: 3SGE BEAMS Timing chain modification?
    Default Re: 3SGE BEAMS Timing chain modification?
    Fark me, what is the box hanging off the radiator support?
    Turbo and intake manifold big enough? They are huge!
    Now - RA23-WRX
    Jun 2011
    Quote Originally Posted by toyota1515 View Post
    I have seen the timing belt modified in the 3S family engines to route the belt in a simple way eliminating the complicated timing belt routing ,
    This is only do-able if external dry sump oil pump is used.
    Feb 2012
    Australia
    That is over kill... I LOVE IT!
    My Daily: NooB's Delivery Vehicle
    My wife's Daily: Series B RA40 Liftback 22RE, power steering, AC. Cushy as.
    Current Project: NooB 3TGTE swap
    Back Burner: 1964 Toyopet ToyoAce, and a Series B TA45 GT coupe
    Too many cars
    Intercooling must be out nowadays Water pump? must be external also?
    If you coul seal up the whole area and lubricate the rubber belt like the new subaru engines, belts are supposed to last the life of the engine.
    Personnally I would bother
    The only belts I've heard of failing before their recommended was on the old Subaru Leone. When they went from pushrod to OHC, the belt interval was supposed to be 100 000km, but they started failing at 80-85 000, so Subaru shortened the interval to 75 000km. Then they changed the design in the Liberty.
    Every other failure has been due to pulley bearings failing or not doing the belt at the specified interval, or something else rather than the belt.
    The advantage of chains (and why they've become a little more popular again) is that they're thinner.
    The last model Holden Craptiva (petrol engine) has issues with it's timing chain stretching enough over as little as 30 000km to throw an error in signal matching between the Camshaft sensor & the Crank Sensor.
    If belt life concerns you, just do it more often. The factory listing is the maximum interval.
    Feb 2009
    MN
    Mitsubishi 4G63s are known to throw belts and destroy heads. I personally know of about 5 such failures over the past 15 years, and none were past the belt change interval.
    Audi 1.8t and 2.7t have been known to drop belts before the change interval too. Audi changed the belt interval TSB on the 1.8t a few years back because of this.
    But they're not toyota. I've never heard of a failure on a toyota that wasn't induced by something else seizing up.
    Dec 2011
    ATL GA USA
    Quote Originally Posted by AE112R View Post
    Yeap, as you can tell from the pictures!
    Dec 2011
    ATL GA USA
    Quote Originally Posted by grue0038 View Post
    The only reason 4G63 messed up belts are "improper installation" otherwise i haven't seen a 4G63 timing belt failure at all!
    VW never messed with them at all!
  1. Timing chain on 22R
    By bec5175 in forum Tech and Conversions
    Last Post: 16-07-2012, 06:25 PM
  2. 18R timing chain
    By StuRT104 in forum Tech and Conversions
    Last Post: 25-09-2009, 10:54 PM
  3. Replies: 25
    Last Post: 02-10-2007, 09:04 PM
  4. 3T-GTE Timing Chain Guides
    By setsuna in forum Tech and Conversions
    Last Post: 01-12-2006, 10:58 PM
