Results 1 to 6 of 6
Thread: Model and frame number for wide body SDV10 Camry???
    Chiba
    Default Model and frame number for wide body SDV10 Camry???
    I'm looking to buy some unofficially cross compatible parts from Toyota for my Corolla Levin, but I need a model and frame number from an SDV10 wide body Camry to get the parts put on file.
    Could some one please provide these numbers at all? You can PM me if you want it kept discreet, I hope my long time membership and somewhat ok rep will indicate I am somewhat trustworthy...
    Default Re: Model and frame number for wide body SDV10 Camry???
    you sure you got that model code correct?
    I've looked up my EPC & all I get is SXV##
    And which parts are you after? May be able to get you part numbers.
    Did you try the Toyodiy site?
    Chiba
    I have part numbers, but I need the model and frame numbers so Toyota can load the part numbers on file. The part numbers aren't in the normal catalogues as they were part of a warranty/recall kit and as such the parts are slightly different to those in the parts catalogue (they are windscreen demister vents with a wider 'flange' to hold down a puffy dashboard).
    The guy at Toyota gave me the SDV10 number, but it may have been wrong, I just need the model and frame numbers of a mid 90's wide body Camry.
    If you want a VIN / frame number and model number just have a look on carsales.com.au there are plenty of Camrys listed
    Jealousy is a curse
    SDV10 I believe refers to the 1994 facelift I believe
  1. removing rear shocks from 93/94 wide body camry
    By mideon_696 in forum Tech and Conversions
    Last Post: 15-01-2006, 12:53 AM
