The belt is called your alternator belt and you need to remove the other two belts in front of it then put on the new alternator belt by loosening the adjuster bolt, lock bolt and pivot bolt till you can get the new belt on then tighten them back up and repeat the process for the other two belts.
Where the wire is broken off in the second picture it is your oil pressure switch wire. It controls the warning light for your oil pressure, just reconnect it and it should be fine.
