Hello and welcome to the forum. This engine swap would require the same things as the vast majority of all swaps. Briefly I'd think about:
- Engine mounts. Use the existing crossmember and make custom engine side mounts, or vice versa. Or track down an AT141 crossmember.
- Gearbox crossmember. Full custom or modify a W58 crossmember to fit the chassis.
- Tailshaft. Most likely custom unless you get lucky with a factory setup and length.
- Fuel system. Convert to EFI pump, etc.
- Misc. All the other bits that you need to connect/convert/wire up.
Also some more effort in punctuation, grammar and tone would probably produce some more helpful responses.
				 how to fit 4agte into st141 corona
