Results 1 to 6 of 6
Thread: how to fit 4agte into st141 corona
    Apr 2012
    Default how to fit 4agte into st141 corona
    i have a rwd 4agte with w58 gearbox that i want to fit to my st141 corona it has a 2sc engine with a 3 speed auto what is needed to fit the 4a with w series gearbox to it??? i don't want to hear why i shouldn't fit it, i don't care what anyone thinks
    Victoria, Mt Macedon
    Default Re: how to fit 4agte into st141 corona
    Hello and welcome to the forum. This engine swap would require the same things as the vast majority of all swaps. Briefly I'd think about:
    - Engine mounts. Use the existing crossmember and make custom engine side mounts, or vice versa. Or track down an AT141 crossmember.
    - Gearbox crossmember. Full custom or modify a W58 crossmember to fit the chassis.
    - Tailshaft. Most likely custom unless you get lucky with a factory setup and length.
    - Fuel system. Convert to EFI pump, etc.
    - Misc. All the other bits that you need to connect/convert/wire up.
    Also some more effort in punctuation, grammar and tone would probably produce some more helpful responses.
    oregon
    pedals..... you will likely need to find a xT14x clutch pedal... and you might have to find both a clutch, and a brake because the auto pedal frequently can't be modified. Along with the mechanical parts of the clutch/brake, you will also need to install the clutch linkage... stock was likely hydraulic.
    Jan 2008
    queensland
    fuel system should be easy
    just use all the lines and the tank and intank pump out of a injected rt142 corona
    the pedals out of any manual 140 corona will fit
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Nov 2011
    south australia
    Quote Originally Posted by rising sun automotive View Post
    how did you go doing this conversion??? as im interested doing this as well. i done some reserch and found out the 4age engine did come out in the corona in japan its a AT141. i went looking around to find one but too hard to find and the one i dod find was far to much. i went to a site called goo-net on google its a japanese car site selling japanese cars.
    Feb 2011
    south australia
    hey i just imported myself a 1983 at141 corona with a 4age and 5 speed. awsome to drive.
    1985 ST141 TOYOTA CORONA SR 5SP MANUAL 2S-C
    1985 RT142 TOYOTA CORONA SR 5 SP MANUAL 22R-E
    1986 RT142 TOYOTA CORONA WAGON 5SP MANUAL 22R-E
    1984 TT142 TOYOTA CORONA GT-T 5SP MANUAL 3T-GTE
    1983 AT141 TOYOTA CORONA GT 5SP MANUAL 4AGE
  1. Corona ST141
    By mark2 in forum Tech and Conversions
    Last Post: 01-03-2011, 07:48 PM
  2. Corona 2sc st141
    By Mechman36 in forum Tech and Conversions
    Last Post: 09-03-2009, 01:37 PM
