Results 1 to 6 of 6
Thread: TPS faulty?
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default TPS faulty?
    Noticed a bit of an issue on my JZX100. According to my Apexi SAFC Neo, the TPS isn't registering anything until I go past about 10% throttle. It was working fine when I installed it months ago and I tried another TPS and its the same story.
    Is there a way of testing it to see if its faulty? I'm about to get it tuned and I don't want things going pear shaped.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    Default Re: TPS faulty?
    can you calibrate the SAFC?
    South Austrlia
    Yeah I did that when I installed it and I tried resetting it to no avail. With the throttle completely closed it reads .6V when it should be 0.
    Oct 2008
    TAS
    You should be able to re learn the safc to the tps.
    1983 Toyota Celica Supra
    get an multimeter, a feeler guage and set the TPS on the throttle body. Then redo the SAFC.
    You wont necessarily have 0v from the TPS with closed throttle.
    eg: http://www.floridasupras.com/mechani...procedure.html
    South Austrlia
    Unlike all the other TPS I've seen before, this one has no adjustment.
  1. how to find out if Cam angle sensor is faulty
    By Thirteen13 in forum Tech and Conversions
    Last Post: 07-01-2012, 11:45 PM
  2. faulty speedo in my MZ20 Need help!
    By iwannagofast in forum Tech and Conversions
    Last Post: 24-08-2010, 07:14 PM
  3. MAF sensor faulty ?
    By greywolf in forum Tech and Conversions
    Last Post: 02-04-2008, 02:12 AM
  4. faulty ABV?
    By akmehd in forum Tech and Conversions
    Last Post: 20-11-2006, 08:05 PM
  5. Faulty Knock Sensor - 4AGZE
    By LoCo in forum Tech and Conversions
    Last Post: 20-07-2006, 02:39 PM
