relays are low-speed switches for providing power to things - the CAS does not turn relays on & off.
The CAS provides timing and cam-position data for the ECU - best way to check whether it's working is to attach laptop/handset to the ECU, run the appropriate tuning software, remove the spark plugs and pull the fuel pump and coil power fuses, then crank/start the engine. The ECU should indicate revs at ~300rpm and be in 'cranking' mode.
If there's no signal, then first check that the CAS is wired up to the ECU (as per the wolf wiring manual) and the wires in question actually connect to the ECU (e.g. are not broken somewhere between the sensor and ECU, test with multimeter). If the CAS is wired up correct but not providing a signal then replace it. If the wiring is suspect, then replace it.
If the ECU is getting a signal but not firing the coil packs, then you need to investigate the wiring from ECU to ingitor(s) and then coils, and also, whether the ECU is configured right.
Before doing any of the above, i'd strongly urge you to get the wiring and software manual for your ECU and read it over and over until it makes sense. Then read it again. After that, go troubleshooting.
Also, get a laptop/handset for your ECU - unless you can see what the ECU is doing, you're flying blind.
