Results 31 to 45 of 54
Thread: 3T Versus 3T GTE conrods
    Perth, WA
    Default Re: 3T Versus 3T GTE conrods
    how to get these rods onto the crank?? it looks like it is in one piece
    Canada
    Could you please post a pic with the big end cap off?
    Seems that the socks came off while you were waiting...
    Breaker of Things 1st year Apprentice setsuna's Avatar
    its extremely well mated pair of surfaces, if you look closely, you can just see a hairline join..
    and with the endcap partially off. you can see a centering dowel type thingy where the bolt goes through into the rod side..
    and it all the way off!
    -DAvid
    They do look like a VERY nice set of rods.
    I was wondering where the join was myself. Very well matted.
    Junior Member Domestic Engineer TA22 GT's Avatar
    Guys,
    I just got some eagle rods and notice that they don't have an oil gallery for the pin? I see a small hole at the top of the rod, I assume this will get enough lubrication?
    Based on this I'm also guessing that I can use either 2T or 3T G rod bearings as no oil hole is needed?
    Simon
    Quote Originally Posted by TA22 GT
    Guys,
    Yes, the little end needs only a very small amount of lubrication. It will get oil that drips off the under side of the piston crown.
    Simon
    I think that the oil squirter hole should be drilled into the rod. This is there to squirt oil on the load side of the bore.
    Quote Originally Posted by YelloRolla
    Jase,
    OK, a couple of dumb questions-
    Which is the correct side and location for the hole? I assume only a small hole is needed, eg 1mm?
    Also what happens if I don't drill the hole and if I do won't it weaken the rod?
    Finally does the stock rod have this squirter hole?
    Simon
  8. #38
    Jase,
    on the right side (from the driver's seat)
    I don't have the definitive answer to the first part of this question: I suspect that there will be enough oil flying around to offer sufficient lubrication to that area, but the factory did it for a reason, so maybe longevity will suffer. As for the rod being weakened; no. rods generally don't break in that area, they break further up the beam.
    Yes it does.
  9. #39
    Thanx Jase, a great help as usual.
    So my best bet would be to drill a hole in the same spot and size as the stock rods?
    Anyone got a pic of the hole in the stock rod? I'm a slow worker and am just gathering bits for a rebuild ATM
    Simon
  10. #40
    Get you hands on a second hand bearing (the 3T bearings have the hole in a different spot to the 3T GTE bearings), and use that as your guide. The hole will only need to be 1.2 to 1.5mm maximum with a chamfer to lead into the hole.
    4340 is tough material. I suggest the use of a cobalt drill, low speeds (relative to diameter - in this case 1200rpm is still slow for the drill), make sure that the drill hole is started with a centre drill and use Rocol RTD cutting compound.
  11. #41
    OK thanks. Can I still buy aftermarket bearings specifically for the 3T GTE from someone like S Wilkins? Or is Toyota the only option for the right bearings?
    Simon
  12. #42
    SW has them listed on their site... maybe give them a call and ask them about it?
    (Im keen to know as I will be going down the same road as you when I get some time and money to play with my 3tgte )
    Toyota Car Club (Qld)
  13. #43
    They're available from other bearing manufacturers. I know that NDC do them, I will see if I can find the part number.
  14. #44
    Simon,
    If your drilling the holes anyway then you can just drill them for the 2T bearings
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  15. #45
    Quote Originally Posted by TheToyman75
    Simon,
    Rod,
    I know the location of the 2T holes are different, but is the bearing width etc the same as the 3T GTE bearings?
    I know its not required, but I think I'll track down the 3T GTE bearings as everything else in the engine will be top quality....
    I'll call Toyota and get a price for them..
    Simon
