Results 1 to 3 of 3
Thread: JZ into IS200 chassis conversion questions
    Jan 2007
    queensland
    Default JZ into IS200 chassis conversion questions
    hi all,
    i know there are a few flaoting around, most of the build threads just sorta show the motor in, big turbo, dyno graph and 'does skids'...
    i'm just trying to clear up a few things before jumping in,
    i have got an Aristo non VVT 2JZ, and i have a GXE10 frame to put it in,
    the car is auto, and i plan on running a A341 of sorts behind it...
    physically fabricating mounts, gearbox crossmember, tailshaft etc isn't a huge problem, but if the IS300 gear can make it a bolt in affair this will save time.. even if i can only use some of it..
    1 - the mounts, i can get IS300 alloy mounts pretty cheap from the US.. not a huge problem..
    2 - rubber mount/insulators - toyo DIY have different part numbers for the GXE10 and JCE10 rubbers.. should be able to source some as they also share the same part number as the GS300 & JCE10 do i need these? i'm assuming they have a different height? smaller or taller then the 1G mounts?
    my main question - will all of this fit onto the GXE10 crossmember? i know the cross members are slightly different.. is this mount spacing?? sump clearance?? etc
    i'll probly have more questions but this is what is holding me back getting a few things together at the moment..
    Mat
    Default Re: JZ into IS200 chassis conversion questions
    are the crossmembers different? They had the same part number between the JCE and GXE from memory when I was researching it.
    Jan 2007
    queensland
    according to ToyoDIY -
    GXE10 - 51201-53020
    JCE10 - 51201-53010
    i am not sure where the difference is between them.. and all my forum whoring can't seem to get any answers, which is odd as it's been done plenty of times before.
  1. IS200 auto box - what is it & general questions
    By mattysshop in forum Tech and Conversions
    Last Post: 12-04-2010, 12:00 PM
  2. 1jz/2jz + Z10 conversion questions.
    By Johnzoku in forum Tech and Conversions
    Last Post: 14-02-2008, 11:29 AM
  3. 20V Conversion Questions
    By GZE16V in forum Tech and Conversions
    Last Post: 14-12-2006, 08:44 AM
