Results 1 to 2 of 2
Thread: Head gasket help
    Jan 2010
    queensland
    Default Head gasket help
    PLEASE HELP I have a 2T rebuilt motor completely I could not get oil up to rocker assembly dropped sump and checked oil pump all OK then took head off and found gasket was partially blocking journal.I checked head gasket on another block and it did not block the journal does anyone here have any info as to what head gasket I may need did Toyota change at any stage will a RA23 fit any info will be appreciated as this is doing my head in
    Dec 2011
    Default Re: Head gasket help
    A ra23 gasket will not fit, completely different engine. As far as i can tell the 2t and 3t share the same head gasket. If it is good on a spare block would have to think it is a problem with your block. You could probably try trimming the head gasket (not really recomended, but what have you got to loose)
    TA23 Celica Convertable *Needs Paint*
    HZJ80 Landcruiser - For driving over Hondas
  1. 20V silvertop head on gze bottom end - head gasket thickness?
    By RT40Corona4AGTE in forum Tech and Conversions
    Last Post: 13-01-2008, 01:15 PM
  2. 3s-GE Head gasket
    By SilverSt162 in forum Tech and Conversions
    Last Post: 03-08-2006, 08:44 PM
  3. 7M-GTE and head gasket
    By kuchie in forum Tech and Conversions
    Last Post: 03-04-2006, 11:37 PM
