mike...voltage at the coil side of the ballast should be 9v , this is because the coil is a 9v coil. When starting the car the ballast res is bypassed so 12v can be applied to a 9v coil...thus stronger spark. so check voltage on the ign side of the resistor and check voltage at pos coil terminal when cranking etc...hope this helps...
leso
			 Coil ballast resistor spec for a flatlight TA22?
