Results 1 to 15 of 21
Thread: Stuck flywheel
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Default Stuck flywheel
    Hey guys,
    The flywheel bolts on my 4A have backed out, I've managed to pull them all out and theres no thread damage however the flywheel itself doesnt want to come out - It starts to move then gets stuck, it's binding up.
    I've tried beating it with a rubber mallet, heat gun, and penetrant/locktite freeze and release. Any body have any suggestions before I go buy a blowtorch? I cant get a puller on anywhere annoyingly as theres no thread on the flywheel itself
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
    Dec 2011
    Default Re: Stuck flywheel
    bolt a piece of plate across the pressure plate bolt holes, weld a nut into the middle of the plate and use a bolt to push on the crank. Sometimes have to do this with trucks....
    TA23 Celica Convertable *Needs Paint*
    HZJ80 Landcruiser - For driving over Hondas
    Jul 2008
    Cheers mate, got it off with more liberal bashing. Alll good
    AW11 Turbo build
    Dec 2011
    more hammer usually works for me too, just a little scared of hitting stuff to hard sometimes. Flywheels can be hard/expensive to get sometimes. My dad does have a saying though, when in doubt, give it a clout, the bigger the doubt, the bigger the clout
    Jul 2008
    Quote Originally Posted by convertableTA23 View Post
    Old man has the same saying, used to work in a wrecking yard when he was in his teens. He was also the one who did the clouting today as I have the same fear
    AW11 Turbo build
    I have had two flywheels do this.
    Once the bolts come loose the flywheel rocks back and forward on the crank transferring metal, this is what is locking the two together Scuffs up to an extent that it damages both. Check the bolt holes in the crank to see if the bolts do not wobble when fully inserted. Check carefully the crank and throw out the flywheel as the flywheel may also have oval shaped bolt holes The crank could have the lumps removed off with a hand file.
    Regards
    Rodger
    Jul 2008
    Thanks mate, yes the flywheel is getting binned, however the crank is fine, some tiny scoring but nothing to prevent reuse. Bolt threads are amazingly ok
    AW11 Turbo build
    Nov 2007
    How did you find this out without ending up with flywheel shrapnel everywhere. Loosened flywheel bolts must have created a nasty vibration. Especially at high RPM.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Jul 2008
    Fortunately I was less than 10kms from home and we caught the noise quite early. Never revved it high
    AW11 Turbo build
    Jul 2007
    because i screamed at him not to rev it on the way home after we noticed the rattle is why
    Jul 2008
    Out of nothing but self preservation for your own spine and not my engine
    AW11 Turbo build
    Bah im sure you wouldnt complain if vito gained a vagina from this experience.
    Jul 2007
    Quote Originally Posted by Harreh View Post
    yes well i did have a vested interest in the flywheel staying together i guess.....
    I would be worried about why they backed out in the first place!
  1. Sump stuck - any ideas?
    By joey in forum Tech and Conversions
    Last Post: 11-06-2008, 02:04 PM
  2. Stuck Throttle Speed On 4K
    By Tham in forum Tech and Conversions
    Last Post: 03-01-2008, 02:10 PM
  3. RA23 Axles Very Stuck???
    By mattlock in forum Tech and Conversions
    Last Post: 14-03-2007, 12:56 PM
  4. Stuck Flywheel bearing
    By RAIncarnated in forum Tech and Conversions
    Last Post: 22-10-2006, 09:38 AM
  5. Stuck oil pressure switch 3tg
    By MarioM in forum Tech and Conversions
    Last Post: 11-02-2006, 05:47 PM
