Results 1 to 6 of 6
Thread: na to vvti swap
    Feb 2012
    New Jersey
    Default na to vvti swap
    I have a 1993 us spec supra and a 1998 vvti motor. Cant seem to get 12v to the throttle valve motor. Any one got any clues?
    May 2010
    Moscow
    Default Re: na to vvti swap
    Depending on how it's wired it may be electrical or mechanical issue. Most obvious idea is that you don't put 12v where it should be...ECU terminal "+BM". Also ECU's for engines with ETCS-I usually have additional ground terminal EC, which is also critical for et. operation.
    btw, 1 or 2 jz? the latter may be immobilised.
    Feb 2012
    New Jersey
    Thanks for getting back, the motor is a 2jxgte vvti 1998 with the newer etcs. I did find 2 ground points in the 1j2 plug that were not grounded and have since grounded them.
    At this point still no power
    May 2010
    Moscow
    You still have to check every pin that needs +12V. Especially +BM, there's no such in earlier models.
    Geroge is right, you need to make sure that the engine ECU +BM pin is powered. I have a feeling that it might not be currently! It is fed from a seperate fuse (ETCS).
    Below is for 2JZGTE VVTi from JZS161, but the +BM / ETCS circuit and engine ECU pin is the same as 2JZGTE VVTi from JZA80
    wilbo666 / 2JZ-GTE VVTi JZS161 Aristo Engine Wiring
    Wilbo's JZA80
    Wilbo's JZZ12
    Feb 2012
    New Jersey
    I have 12v to all the points on the ecu and found on the 1j2 plug pin 8 and 9 are grounds and not on the 1993 na harness. All are grounded now but still nothing no
    power to valve motor.
  1. Replies: 40
    Last Post: 04-02-2018, 06:44 AM
  2. mkIII supra 1jzgte vvti motor swap questions
    By supradrew in forum Tech and Conversions
    Last Post: 28-01-2011, 01:00 AM
  3. mx83 cressida - vvti 1j swap
    By KAMAKAZ in forum Tech and Conversions
    Last Post: 29-06-2009, 02:26 PM
  4. vvti 1jz - non vvti 1jz, timing belt
    Last Post: 24-06-2009, 05:01 PM
