Results 1 to 5 of 5
Thread: Radiator fan keeps on running? proper wiring with thermostat @ AW11?
    Nov 2011
    Luzo
    Default Radiator fan keeps on running? proper wiring with thermostat @ AW11?
    Good day guys!
    I would like to ask how or what is the proper wiring of the radiator fan from my 4age 16v bluetop (AW11). since my last radiator overhaul the mechanic rewired the radiator fan and i think he wired it the wrong effn way that it keeps on running and never stops, checked my thermostat already and still working. then last night the fan blade came off, the base mounting melted off..
    here's
    http://cdn.sulitstatic.com/images/20...d5a898b297.jpg
    Junior Member Backyard Mechanic benjamin's Avatar
    Default Re: Radiator fan keeps on running? proper wiring with thermostat @ AW11?
    my adub did this after I swapped radiators. Turned out that the temp sensor screwed into one of the end tanks was faulty. Due to this, the controller ran the fan all the time. Try swapping out the temp sensor (or checking it's plugged in)
    Nov 2011
    also toyotas wiring is so there is a safety on the system
    if the wire from fan temp sender to the fan relay gets cut
    it turns the fan on
    also if your air con gas gets low or is gone fan also comes on too on some toyotas
    so could be anything
    most mechanics dont realise toyotas work a different way so they fk things up in the end
    Jan 2011
    Im sory if this doesnt help... I blew a fuse once under the dash, that kept my fans running, cnt remember which fuse, but it did do it??
    Mayb worth a look??
    Dom
    May 2007
    victoria
    I'd be checking your plug first.
    Like dumbass said If there is a fault the fan will stay on.
    it's a naturally closed relay...
  1. Running wiring through stainless braided line
    By obrim in forum Tech and Conversions
    Last Post: 17-06-2010, 01:03 PM
  2. Running without Thermostat - Cools better?
    By kylestyleup in forum Tech and Conversions
    Last Post: 21-01-2008, 08:56 AM
  3. proper 3TC oil pressure
    Last Post: 28-04-2006, 09:16 PM
