Results 1 to 14 of 14
Thread: 1Uz ecu which to use Haltec,stock Soarer or uzs131 crown?
    Jul 2011
    Question 1Uz ecu which to use Haltec,stock Soarer or uzs131 crown?
    1Uz ecu which to use Haltech,stock Soarer or uzs131 crown?
    I have one of each and stock looms for each soarer and crown, which will take the least effort to run the 1UZ as a stand alone manual engine? That I'm fitting in to my 4runner
    I have read most of the 1UZ threads but have not found many that use a Haltech.
    Advise on which to use would be great.
    Default Re: 1Uz ecu which to use Haltec,stock Soarer or uzs131 crown?
    The answer may depend on which 1UZ you have
    Jealousy is a curse
    If the engine is staying stock, just use the stock ecu.
    Soarer wiring diagrams readily available.
    Nov 2011
    what haltech do u have
    new ones work ok with toyota reluctor sensors
    older haltechs have issues
    trust me i had to fit an e11 to a 1uz and it turned to shit
    Nov 2011
    also what gbox r u running
    if going auto then u need afew things to look at before u decide
    if its a pre '94 soarer engine and ecu you can also disconnect the MAF sensor and get a nice performance bump (at the expense of fuel economy...)
    Jul 2011
    It's stock "92" soarer 1uz with the 4runner r150 gearbox.
    as the crown engine has a 75% chance of going into a ski boat
    The Haltech is a platinum sport 2000
    Nov 2011
    ok cool
    sport series are good
    Jul 2011
    Can anyone send me a "92"Soarer wiring diagram ecu#8966124220 or uzs131 wiring diagram ecu#8966130431 or links to pls
    May 2010
    Moscow
    ECU pin configuration?
    Jul 2011
    soarer ecu is 80/40
    May 2010
    Moscow
    same as '91 aristo. occasionally I got one. send me blank email (see profile) and I'll answer in a day
    If you have a Sport 2000, you've done well. I have my 1uz run by a Sprint 500 and it does the job fine.
    Facebook | LinkedIn
    91-93 Soarer ECU pinouts (japanese one) plus US SC400 pinouts included for pin descriptions
    [edit] ffs what is with the lame file size limits?
