Results 1 to 12 of 12
Thread: A01A/A01B IS200 diff interchangeability
    Jan 2007
    queensland
    Default A01A/A01B IS200 diff interchangeability
    hi all,
    my auto IS200 has an open centre, say i wanted to put an LSD of sorts in there...
    some of my options are
    1 - get a manual IS200 diff, but this is an A02B, different ratio..
    2 - JZZ30 TT diff, A01B same ratio but LSD..
    being 10 years between generations, i just wanted to confirm some measurements with someone who has a JZZ30 diff 'laying' around..
    this IS NOT a picture of my particular A01A.. i just googled a quick pic of a similar diff, pretty sure it's a supra TT diff (probly even the same but LSD)
    both the tail shaft, and the drive shaft bolts are 4 stud, and i've measured using a tape measure... i figured they will be close enough within mm, or completly different.. i can measure again once it's on the hoist.. i forgot to measure a few things.. the overall length is from pinion flange to rear housing gasket face.
    Default Re: A01A/A01B IS200 diff interchangeability
    I've been looking into this also, seems if you can get your hands on a JZX100 diff/housing and shafts it all bolts in and is a decent upgrade. Auto JZX100 is 3.9:1 and manual is 3.7:1.
    I'm waiting for one of the QLD guys to write their car off and planning to buy the complete rear assembly.
    Jan 2007
    queensland
    i can't just bolt the diff in?
    it's a bigger/stronger diff, more like IS300. The housing etc will bolt into the 200's rear subframe.
    Getting the complete rear assembly also makes it easier for me to do a rear 2 piston caliper upgrade
    Jan 2007
    queensland
    i think i know where your going JP, and i definitly will not need that sort of power handling, you might though haha
    back to the original question...
    the JZZ30 A01B
    do they use 4 bolt pinion flange, and driveshaft flanges?
    alot of diffs i've seen use 3 bolts...
    JZZ30/JZA80/JZS147 etc diffs will not fit IS200, they are bigger
    they are 3-bolt pinion flange, 6-bolt axles
    Wgtn
    This is where toyota made it a mess.
    An Altezza RS200 / IS200 has an A0** which is similar to an old F series, ie. 7.5" CW
    Where as the Gita / IS300 has a B0** which is similar to an old G series, ie. 8" CW and an A0**from say...
    a JZZ30/JZA80/JZS147
    An A0** is a 8" CW
    and a B0** (6spd JZA80 only IIRC) is a 8.5" CW
    New Zealand
    Get manual LSD centre and swap crown wheel?
    Callum
    Jan 2007
    queensland
    Quote Originally Posted by WDE_BDY View Post
    Callum
    love the simplicity of this.. unfortunatly though just getting a manual LSD centre is a bit of a difficulty, unlike NZ i have never ever seen an IS200 at the wreckers,
    cheers for the info thus far guys...
    i really should have just got an IS300 lol...
    Jan 2007
    queensland
    thats good the 4 cyl SXE10 has an A01B in it.. this may work out
    cheers Callum
    New Zealand
    That was the first one I found, I bought one sub $300NZ a couple of years back.
    Callum
  1. Ma61 diff centre -> Is200 diff
    By Hash_ra23 in forum Tech and Conversions
    Last Post: 03-01-2011, 11:51 PM
  2. JZA80 A01A w/ W58, fit LSD?
    By ark_112 in forum Tech and Conversions
    Last Post: 02-05-2009, 11:02 AM
  3. HELP... 3SG motor n A01B rear diff into GA61
    By kanazai2001 in forum Engine & Driveline Conversions
    Last Post: 30-11-2006, 08:10 PM
  4. A01B diff ratio??
    Last Post: 08-11-2006, 12:14 AM
