Results 31 to 45 of 46
Thread: 1jzgte vvti turning off
    Dec 2011
    BC
    Default Re: 1jzgte vvti turning off
    what about the fpc?
    May 2010
    Moscow
    I don't use fuse boxes, just connect wires 1 by 1 looking at wiring diagram
    Dec 2011
    BC
    cool ..................... did you coneccted the fpc?
    May 2010
    Moscow
    I connected one relay that actually controls fuel pump to FC pin
    and another relay to fool ECU to FPR pin
    nothing more related to fuel pump
    Nov 2011
    doesnt matter if throttle works on now
    its just that the ecu controls the fbw
    anyway i cant tell u if running cable throttle on fbw ecu works
    ive never had to dodgey it up like that
    maybe others can help from here
    Dec 2011
    BC
    thanks dumbasss for your help
    i think i only need more poer to the fuel pump or fool the ecu that that the fpc ecu is getting high voltage that way it wont turn off i think
    May 2010
    Moscow
    there's no fpc ecu in jzs171. engine ecu does everything.
  8. #38
    Dec 2011
    BC
    because when i recived the engine it came with a kinda like a liltle amplifer i think is call fuel pump resistor
  9. #39
    May 2010
    Moscow
    yes that's a resistor you don't need it. Just one relay for real and one to fool ecu
  10. #40
    Dec 2011
    BC
    Definetely I will try it and I will se if that fixes the problem
  11. #41
    Nov 2011
    run fuel pumppwer direct to battery positive jsut for one drive to see if it cures yr problem
  12. #42
    Dec 2011
    BC
    Its not like the fuel pump is turning off its more like the ecu shuts down the engine when its on high boost
  13. #43
    Would be a good idea to wire up the fuel pump relay as in the wiring diagram and get rid of that 78 code. The ecu expects to see that relay
    Jealousy is a curse
  14. #44
    Nov 2011
    id be more worried about fbw setup than code 78
    ive never seen that cause problems
    also have u tried running low boost
    stop wirrying bout the stupid things liek fuel pump and air flow
    if its a hi boost problem drop the boost
  15. #45
    Dec 2011
    BC
    Yeah sounds like a good idea but how can I lower the boost on the turbo ........ And what does everyone think about a stand alone computer for a daily?
  1. 1jzgte vvti or non vvti
    By Axil in forum Tech and Conversions
    Last Post: 21-04-2011, 11:56 AM
  2. Twin turbo 1JZGTE or vvti single factory turbo 1JZGTE ???
    By matt_spitfire in forum Tech and Conversions
    Last Post: 30-03-2010, 11:48 PM
