my under standing is you don't use the trigger angle to adjust the timing,
you should set trigger angle (3sgte is about 60 deg) and then lock timing to 10' and vary the tooth off set until you get close and then fine tune the timing with the distributor.
be aware it is possible to be 180 degrees out, so you may need to move your tooth off set up or down 12 teeth to get the spark on the power stroke.
lastly check your miss counter, also are you getting fuel? deffinately enabled injectors etc?
these are the things that caught me out with my 3sgte,
