Results 16 to 22 of 22
Thread: Tomei's new ARMS M8280 Bolt on kit for single turbo 1JZ's
    Default Re: Tomei's new ARMS M8280 Bolt on kit for single turbo 1JZ's
    I'd love to see some real-world comparisons of this Tomei turbo compared to stock. Sure, there's dyno sheets above (which contradict that the replacement turbo has the same response, clearly there's a torque hole on the graph compared to stock), but generally, a GT35r sized turbo is gonna be significantly lazier to respond than a 3076 (i've run them back to back for info). I know the newer generation turbos are much more efficient than the older toyota design, but its still a BIG jump in wheel size regardless.
    Seems they might be built to a price to some extent also, having stuck with journal bearings rather than new gen ball bearing cores?
    Still excellent value for money though, i'd not hesitate to try one
    Aug 2009
    Cool, thanks for that link. Interesting to note that vehicle in Japan runs an Australian Haltech ECU hey.
    May 2006
    tas
    Yeah i noticed that, quite a interesting video. Japan doesnt have many good ecus, Power FC is outdated and most of the others are piggypack computers.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Jan 2011
    queensland
    Sorry for the bump. just wondering how many guys have used this upgrade and if they have had any problems. and if there is any better option.
    Junior Member Backyard Mechanic Valkyrie's Avatar
    Tasmania
    http://www.ebay.com.au/itm/Kinugawa-...ht_2046wt_1189
    It is obviously cheaper, but I don't know whether it will produce more power.
    [ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "You live"
    The software required Win95 or better, so I installed Linux.
    4AGZE into TA22 http://www.toymods.net/forums/showthread.php?t=16775
    1JZ powered RA60 https://www.toymods.org.au/forums/th...light=1jz+ra60
    Aug 2009
    chinese turbo + no way it can make more power it uses the stock sized turbine wheel
  1. 1jz single turbo VVTI block differences to 1jz twin turbo
    Last Post: 06-02-2008, 12:57 AM
