Results 1 to 10 of 10
Thread: YN57 Hilux 3Y Ignition Upgrade Help & Hot Start Problems.
    Dec 2011
    Default YN57 Hilux 3Y Ignition Upgrade Help & Hot Start Problems.
    Hello All. New to the toymods forum.
    I'm having problems with my 1983 YN57 Toyota Hilux, 3Y Carb. 2WD
    Last week I changed the engine oil and checked the timing as is has been pinging.
    While checking the timing I noticed that the mark moved around a lot so I check the dizzy shaft and noticed a bit of excess play and the vacuum advance is not working/leaking.
    Must be the reason for it pinging.
    If I could locate a second hand electronic Ignition distributor complete from a wrecker, I think it has two vacuum advance connections? How do I hook up the second connection as mine has only one?
    Second option is to get a new aftermarket 4Y Electronic External Igniter Distributor complete from Rolin automotive imports for $275. I think there Chinese made.
    I have searched online high and low to try and find some help. I do remember reading somewhere that the aftermarket ones don't last.
    Has anyone tried these out?
    Third low cost option?
    The other problem I'm having is when the car is hot (normal temp) after 30mins or so it's hard to start - cranks over a long time before it starts. Always starts fine when cold?
    What do you guys think is causing this problem?
    Thank you for reading. Any help would be greatly appreciated.
    Lee
    spank that naughty.. Grease Monkey
    Aug 2010
    country Victoria
    Default Re: YN57 Hilux 3Y Ignition Upgrade Help & Hot Start Problems.
    timing ?
    put some 95 fuel in and see if the pinging stops,
    not sure what you mean by not working/ leaking
    if the advance isnt hooked up ...it wont be advancing so thats not your problem , more likely the base timing (or the worn parts making things eratic)
    you may be able to swap your (good) single vac advance unit onto the new dizzy , mine had a grub screw to undo and a wiggle and it was out .
    my chinese holden dizzy (NOT FROM ROLLIN IMPORTS )flew to bits at 100 kph after a few weeks mild use ,
    the internal timing gears were in a million bits.
    it looked and felt sloppy , but the blurb said how excellent it was and i was in a hurry and ran with it........
    they offer a 3 yr warranty so i posted it back
    they asked what coil i was using ( ! ) and im still waiting
    factoring in the cost of the tow and time off work , it was a mistake
    Remember this is a recreational activity ......
    we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
    the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
    Dec 2011
    [QUOTE=Suavemechanic;1403378]timing ?
    Thank you for your reply
    The Vacum advance is connected, but when tested I found that the diaphragm/bellows is leaking alot.
    So as the vacum advance is leaking and there is lots of play in the dizzy shaft I thought I would try and replace the whole distributor with a electronic ignition setup.
    I think I would prefer trying to locate a good second hand Toyota one instead of a Chinese item.
    Bit of a bugger about your chinese holden dizzy. As if the coil had anything to do with it falling apart. lol
    Aug 2010
    country Victoria
    Hi ,in the short term block up / off the vacuum hose to the carb so you arent sucking air in . it might improve idle and starting a bit.
    there are people who specialize in vac cans if you cant find a nice one at the wreckers
    just been through all this on two cars in a row and once its working nice it is so worth it !
    cheers !
    Jan 2008
    queensland
    you might be better off trying to find a elec dizzy out of a tarago 3/4y
    if the top bush is flogged out it should be cheep but easy to fix
    if you strip the dissy and give the housing and shaft to a engeering shop they will turn you up a new bronze bush and fit it
    used to have them done for about 75 bucks
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    vic
    Quote Originally Posted by litldv8 View Post
    you might be better off trying to find a elec dizzy out of a tarago 3/4y - neil
    what do you need to do (ie vac advance and power) to make this setup run?
    ive got one of these for my dads yn57 but never knew what to hook up on it.
    Dec 2011
    I have blocked off the vacum advance temporary until I can source a replacment.
    I'll go to the two local wrecker when they re-open in a week or so after the christmas/new years break
    I hope one of them has a good electronic distributor or I'll have to try and re-build my one.
    Jun 2007
    I fitted a Crane XR700 electronic ignition conversion kit to my Hilux years ago and it is still going strong. It cost around $250 when i bought it. Timing moving around is usually caused by stretched or broken springs in the mechanical advance mechanism of your dizzy. I would get another dizzy from the wreckers rather than a crappy chinese one and put an electronic ignition conversion kit in it if they are still available.
    Dec 2011
    Thanks Dazza.
    I'm going to a wrecker on Tuesday when it re-opens. I just hope they have something for me. Preferably a Electronic Carb 4Y Distributor.
    If not I might have to ring around a few other places around Australia and get them to send it to me and just hope it's a reasonable one.
    Aug 2010
    country Victoria
    Hi
    make sure you get the module too or it wont go ,and the next six modules you get wont be quite right
    there is an electronic " points eliminator type kit " on ebay at the moment
    that looks interesting...
    if you get stuck search electronic ignition coversions here there is an excellent tutorial
    but if you have a wobbly shaft id get that sorted first...
    good luck at the wreckers....
  1. Hilux yn57 + New Engine !!
    By Hilux_86 in forum Tech and Conversions
    Last Post: 19-07-2011, 10:12 PM
  2. old hilux master cylinder yn57 Q's
    By datfreak in forum Tech and Conversions
    Last Post: 17-04-2010, 09:08 PM
  3. Yn57 Hilux Thermostat Location
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-09-2006, 10:40 PM
