Results 1 to 2 of 2
Thread: 1jz water pump fan clutch... i think
    Apr 2010
    Default 1jz water pump fan clutch... i think
    Hi, im looking at a chaser, and they have had the AC compressor replaced recently;
    A/C compressor was fked due to the fan clutch not working...
    and replaced the A/C compressor now air cool....but only need replace engine fan clutch
    now, im not all that up with AC stuff, but i wouldnt have thought the fan clutch would have any effect on the AC comp at all... May be wrong though
    had a look on the toyodiy,
    ToyoDIY.com
    thats the only fan clutch i could find
    would the two things be related? or would it just be both stuffed up and they assumed they had a common cause.
    Any help would be useful
    (i may have not made alot of sense... pretty tired, and therefore dont know what im saying much )
    Tallahassee, FL USofA
    Default Re: 1jz water pump fan clutch... i think
    Doubt it.
    If it wasn't cooling well only when stopped or going less then 20kph, then the lack of airflow through he condenser would be suspect, but breaking the compressor - low pressure from internal failure, seal leak or clutch - is hard to do other then just plain worn out, especially if its high&low pressure switches are working.
  1. Is 4ac water pump same as 4age rwd water pump?
    By s2k in forum Tech and Conversions
    Last Post: 25-10-2007, 09:55 PM
