Results 16 to 23 of 23
Thread: 1MZFE in SW20 wont start -factory immobiliser - solved
    Western Aus
    Default Re: 1MZFE in SW20 wont start
    problem solved, i shall do a write up of how to wire toyota imobiliser systems shortly!
    wa
    Default Re: 1MZFE in SW20 wont start -factory immobiliser - solved
    Was it the key switch in the barrell?
    Western Aus
    the blue/black wire is the "key warning switch"
    basically, its a switch inside the key barrel to tell the ECU that theres actually a key in there.
    if you try to hook the lot up without grounding the switch, the ecu knows somethings up.
    so, i just grounded the wire, hooked up the yellow and yellow/black to the "a" plug (since there are two of each wire, it took a bit of switching around) and vroom, she fired!
    Aug 2009
    Whats the 'a' plug? Did you end up using the transponder and chip our just grounded the warning switch wire? Good job tho
    Western Aus
    you need the whole lot.
    when you pick up a 1MZ engine package in australia, you need the loom, ecu, key, key barrel magnetic ring (the part that has "acc", "on", "start" written on it, and the key transponder amplifier/immobiliser ECU.
    the "a" plug is the 28 pin connector, with b being 16 pin c 22 pin, and d the big bastard, 34 pin.
    Aug 2009
    Ahh I see, awesome stuff
    so does it do mad skids or what????
    Western Aus
    waiting for my fuel pressure guage to get here so i can set the external fuel reg.
    unfortunately, i managed to get a hold of a wrecked MCV20 camry after i did the conversion, hence i have all the bits to do this conversion again, this time, using the camry in tank fuel pump/reg.
    it runs, and drives though!
  1. 1jz wont start :(
    By skin in forum Tech and Conversions
    Last Post: 11-11-2009, 07:48 PM
  2. help,car wont start
    By Chalk in forum Tech and Conversions
    Last Post: 26-02-2009, 10:12 PM
  3. 3tc wont start please help
    By Cob604 in forum Tech and Conversions
    Last Post: 29-07-2008, 06:56 AM
  4. mr2 wont start
    By KARNAGE in forum Tech and Conversions
    Last Post: 09-03-2008, 07:10 PM
