yup, stick it on TDC, theres marks on the oil pump for the crank and a mark on top for the cam, (make your own marks if you want) and mark the rotor in the dizy to make sure you get that back in the right place. (the dizzy will turn as its a helical gear, so youl have to move it 1 tooth, so it turns it self into the correct position.)
turn the crank 720 degress make sure all marks line up, then check the timing after.
