Results 1 to 9 of 9
Thread: VIOLENT shaking from front suspension UZS131.
    Jul 2010
    wa
    Default VIOLENT shaking from front suspension UZS131.
    I've been driving it around in pimp mode for a few years and it drove normally (if a bit bumpy), when I raised the ride height I get intermittent SEVERE vibration from the front end.
    Thoughts?
    Thanks in advance.
    Nov 2011
    Default Re: VIOLENT shaking from front suspension UZS131.
    You think it is from the front... Check the rear end. My Celsior did this due to a flogged out rear hub as one of the CV nuts had been left loose prior to purchase
    His. 2005 GRJ120 Prado VX
    Hers. 1995 KZN130 Surf (soon to be replaced by a Rav4)
    1981 LN40 Hilux Trayback ute. Now an RN40 with Surf interior
    1992 Factory Widebody 2door Surf 1UZ-FE V8 Auto, now for sale
    Aug 2009
    Vibration when? Low or high speeds? Any play in wheel bearings or steering tie rods?
    Act
    Castor rod bushes...
    they shit them often enough...
    Jul 2010
    wa
    Quote Originally Posted by pandaah View Post
    It started doing it at about 70km/h I pulled over and checked for play in the wheels but couldn't find any. I tried to limp it home that way but the vibration always came back. It was so violent that it cause the muffler to smack against the car underbody.
    So I tried lowering the ride height to it's lowest setting and that fixed the problem.
    Aug 2009
    Have your balanced your tyres?
    Act
    Castor rod bushes, with the ride height low its loading the castor rod up and when the car is at "normal height" the tension is released on the castor rod and you get the awesome play/vibration that you experiencing
    Jul 2010
    wa
    diag_1rwyR5L.pngOk Thanks alot guys.
    Is this the bush?
    Act
    those bushes probably aren't the best..
    not the castor rod ones though. Castor rod runs from the front lower arm up the front of the chassis. Has a bush on each side as it goes through the chassis.
    Get a suspension place to look at it for you see if they are the ones that are shagged, ten get replacement ones. yo can try using MS112/MS123 as these where Aus delivered. Also cut 10mm or so of the crush tube that runs through the bushes. This will allow you to run them a little tighter
    Stitt
  1. UZS131 Suspension related wiring diagrams?
    By desty in forum Tech and Conversions
    Last Post: 02-05-2011, 09:35 PM
  2. UZS131 Crown air suspension trouble. Workshop in Perth?
    Last Post: 12-04-2011, 07:12 PM
  3. UZS131 Crown Air Suspension Not Remaining Level
    By MS112 in forum Tech and Conversions
    Last Post: 15-03-2011, 07:25 PM
  4. uzs131 rear suspension (airbag to spring)
    By japlish in forum Tech and Conversions
    Last Post: 28-09-2007, 07:04 PM
  5. UZS131 air suspension?
    By orestes in forum Tech and Conversions
    Last Post: 02-03-2007, 06:45 AM
