Hi Jondee,
Re. Issues:
I finally got the Vac system finished today, using your basic layout and yes, it’s a hell of a lot neater than what I had. I will outline what I did at the end but first I have to say that – despite all that effort, my MAP vacuum is still ~ 70kPa - with ISCV attached (haven’t tried it w/ ISCV disconnected as I don’t see the point; with P/S & Air I need it.).
At the moment the cars not running right – it idles at ~3700RPM for 15-20 sec and then “pulses” I.e. too much air / not enough vacuum so the engine revs out, then goes into idle cut mode, and keeps cycling this process.
{Funnily enough, on my first tuning attempt it was idling rough but steady at about 900RPM – but this was because the throttle linkage was fouling on the Fuel Rail & only had ½ the proper travel – so the 100% TPS deflection value “learned” by WARI was only about 1200; about 50% of proper figure of ~ 2150.
I was quite careful with the vac lines, made sure all were properly pushed onto Barbs + secured with zip-ties so it’s unlikely a Vac leak is causing above issues but I’ll start it up again 2morrow & pour water all over intake & see what happens.
Re. Actions / Remedy:
Not sure what I should do;
1. I.e. just accept that this is the best vacuum I'm gonna get and tune according to these parameters. I took the car for a drive; yes the brakes seemed a bit lifeless but they were OK; not a patch on the AE111's in terms of feel though. . . and no I haven't tried turning on the Lights & A/C. . .
2. (Assuming I can't solve it) Take the car to a professional to see if they can diagnose / improve the Vacuum System. I don't like this option as its likely to involve considerable expense - BUT if anyone knows a workshop in Sydney with good 16V 4AGE+Quads credentials I might consider dropping in to see them.
Re. 20V ISCV:
Being as this beast seems to be the fount of all my problems I wanted to at least make sure I’ve plumbed it correctly. You said “When you look at the factory ISCV you should be seeing something like a 12mm tube on the airbox side, and something like a 15mm tube on the throttle side”.
I think I’ve got mine “wired” opposite to this, with 12mm tube running to Collector, and 15mm tube running to Airbox / Plenum as outlined by this article >:: DIY Stuffs < 1/3 down page >. Can you confirm the right layout; and whether (if I DO have this ass-about) this may be causing my problems?
Re. Layout:
I should have taken pictures I know but I’ll try & explain what I’ve done.
I used a modified Big-port Fuel Rail @ yourself and tapped 1/8 BSP Barbs into u/side of T3 Manifold about ½ way between Head / ITB Mating faces. I used the 4 Injector holes + had another 3 tapped into Rail between existing holes. I also had FPR hole tapped out ¼ BSP to fit a Vac union for the 20V ISCV. So I have 7 1/8 BSP outlet Barbs; 4 to ITBs, and 3 plugged.
Not sure why you didn’t mention it but I couldn’t believe how lucky it was that Fuel Rail Mount Hole Pitch (~ 87.5mm) = Pitch between Mount holes in ITBs for OEM S/T Vac Line Bracket; i.e. Fuel Rail bolts directly to ITBs w/o any modifications – brilliant!
In place of your custom smaller cylindrical Collector for MAP / FPR vacuum I used an eagle box I got from T3 Tuning. I tapped two holes in Fuel Rail / ISCV Collector and Piggy Backed Eagle / MAP Collector directly onto it.
I had the six 1/8 NPT | 5-6mm Nylon Barbs that came with it turned down to 4mm and ran 6 X 3mm Vac Lines to original 1/16 NPT Barbs on T3 Manifold; 4 to ITBs, 1 to FPR and 1 to Dashpot* / Oil Canister (this was running direct to little OEM outlet on top of #1 ITB but I re-routed it to use up spare outlet. I then ran 4mm Map Vac line to one end outlet on Eagle Box (other end plugged).
