Whats the motor in? I've seen the stock plenum modified, and something with the trumpets changed also.
OK; I know this isn't going to be news to any / many that have done this conversion but the stock S/T Plenum won't fit so I'm looking at what my options are (running open with sox / sausage filter not at option right now).
Tried fitting it upside down but still doesn't work.
Only seen 2-3 that do the Job @ below;
1. Noby Booth
2. Toda - Carbon.
3. Custom S/S unit from NZ (looks great)
I was kind of interested in option 1 (i.e. cheapest) but was a bit concerned with how durable a plastic plenum box would be in the long term.
Would like to hear from anyone who's come across / used these things w.r.t. above.
Cheers.
AE92.
Another suggestion that's been made is to use a Pulsar GTiR Plenum but I've only seen it mounted on a S/T , B/T in RWD configuration so it would have to be mounted u/side down for AE92 so inlet is on the right. Again though, no confirmation it would fit with lower mounting of Quads @ Big port but it IS much shallower than S/T Plenum. Might try get my hands on one to see if it fits.
OK; have figured out basic reason S/T Plenum won't fit - should have looked for the obvious first. . .
TB flange face isn't symmetrical, with adjusting screw on one side. T3 manifold mounts TB's u/side down so adjust screw flange fouls on S/T Plenum recess, which is only wide enough for mounting screw @ other side of TB.
