Results 1 to 4 of 4
Thread: 1uz vvti help
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default 1uz vvti help
    I'v got a problem with my 1uz vvti and I'm completely out of ideas. Here's a description on whats happening.
    It misfires at idle but only when warm. It's fine on cold start. In park and neutral it misfires all through the rev range. In drive,reverse,2,1, if you just slightly raise the revs to 900-1000rpm and above the misfire goes away and the motor runs great. Also the misfire is coming from cylinder 1. Here's a list of things that i'v tried.
    Compression test 175 - 180psi on all 8
    Leak down test all good
    New spark plugs
    Replaced Maf
    Replaced o2 sensors
    Switched coil pack from another cylinder
    Switched injector from another cylinder
    Injector is pulsing
    Coil is firing
    Cleaned throttle body
    obd2 scan only codes are for the rear o2 sensors, car ran fine without these for a few weeks before this problem started.
    Checked for vacuum leaks
    Checked shim clearances
    Any input would be greatly appreciated.
    1994 GZX90 Mark II 1GZ-FE V12
    Default Re: 1uz vvti help
    Presumably runing on factory ECU, could be the usual dry caps problem? That can cause wierd shit on non-VVTi's...
    May 2010
    Moscow
    Would highly recommend to check sensor readings with obd2 scanner. Among other things that would confirm dead caps.
    There's a quick and dirty way for troubleshooting sensors (and their ECU inputs). Just disconnect them one by one thus entering limp mode and see if something changes.
    Also, since yours is vvti engine, there's quite common problem that control valves (and rarely cam timing gear) get stuck somehow. Even if you pull valve out and check that it moves ok when you apply 12v to its terminals, there's still a chance it would stuck when put in place. This kinda behavior is usually associated with vvti and cam sensor error codes, but I know some cases when the problem was in the vvti control valve and no vvti-typical errors were read.
    Hey man
    I couldn't find those 4 wire sensors...
    -RM
  1. Replies: 40
    Last Post: 04-02-2018, 07:44 AM
  2. 1jzgte vvti or non vvti
    By Axil in forum Tech and Conversions
    Last Post: 21-04-2011, 11:56 AM
  3. 1jz non VVTi - 1jz VVTi differences?
    Last Post: 15-09-2009, 07:34 AM
  4. vvti 1jz - non vvti 1jz, timing belt
    By KAMAKAZ in forum Tech and Conversions
    Last Post: 24-06-2009, 06:01 PM
