The Radiator isnt the problem, its the airflow at low speed that is, there simply isnt enough air being pulled through without a shroud, the 2x fans I have really only act on maybe 50% of the radiator, so its unfair to blame the radiator and again when you are moving the temps go right down so its doing its job (the rad). I would reccomend that if you can doing a shroud and fan or just shroud option on your radiators.
Im ditching the 1g and going something else which required a complete custom IC/rad setup so im in a different boat again.
