Results 1 to 6 of 6
Thread: Starlet radiator cooling capacity
    Junior Member Grease Monkey ra65's Avatar
    Default Starlet radiator cooling capacity
    I just put a starlet radiator in my corolla because it was pretty new looking and there were no 4ac ones to be found anywhere on a friday afternoon.
    Will the cooling capacity of it be any worse than an old fairly rooted 4ac radiator? Its about the same surface area but the tanks look slightly smaller.
    Default Re: Starlet radiator cooling capacity
    For anyone that cares it runs cooler around town and at 110.
    As long as it has a similar area and thickness it should cool fairly similarly I would think.
    110 sounds warm although I guess it depends on where you measure it from.
    Just after the water leaves my 4ag it is around 86 around town? Maybe the 4ac is supposed to be different... I have never seen my water above 95/97.
    Anyway least you have found a solution.
    110km/h - sits on halfway, with the old radiator it was in between halfway and hot.
    lolz, 110, thats a good temp
    Cooling systems are rarely used at or near capacity.
    An old, large (and partially blocked) radiator will be a lot worse than a brand new, smaller radiator. If the surface area is roughly the same, and it's new, you shouldn't have any problems.
    Mos.
  1. A simple stroke vs. revs vs. capacity comparison
    Last Post: 01-10-2006, 03:22 PM
  2. 4E-FTE Starlet torque settings????
    By AE92 Rolla 4A-GTE in forum Tech and Conversions
    Last Post: 24-09-2006, 11:05 AM
