Originally Posted by
oldcorollas
Tham, perhas you could try runnign with less than 20deg advance.. try 15 and see if it makes a difference.
Thanks, will try that again.
I did try that setting when using points (with or without
the High Energy Igniton unit), and it was very sluggish
and had trouble climbing slopes.
I pulled the No.1 plug out as advised by ToyCrash in
the other thread, looked at the the top of the piston,
noted the timing marks on the cam cover and the
position of the distributor rotor, and it appeared to
be at the proper TDC.
