Page 3 of 3 FirstFirst 123
Results 31 to 39 of 39
Thread: mkiv supra 1jzgte i think over fueling it want start.
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: mkiv supra 1jzgte i think over fueling it want start.
    Contact Steve Smith at Smithie's Soarer Sanctuary as he's always wrecking Soarers and would possibly have a parts twin turbo Soarer or two around Smiffie's Soarer Sanctuary
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    Aug 2011
    lincolnshire
    hi i have finaly got the map sensor and it has sorted the running problem buzzing. thanks guys for the help.
    the problem i have now is air in the water system and the batt not chargeing apart from that it runs quite well.
    does anyone have any idea where i might of gone wrong on the chargeing side of it.
    big thanks to wilbo that has made this project happen. MUCH APPRICIATED
    THANKS LEE
    Aug 2009
    Does your battery light work on the dash?
    Aug 2011
    lincolnshire
    Yes my batt lights on before starting then goes off when started. Cheers lee
    Sep 2009
    is the alt sensing wire hooked up?
    Aug 2011
    lincolnshire
    I think so iv put a new batt on today just to see if it is the batt. And I keep getting air in my water system. Iv run the car with the cap off till it gets hot I turned heater full on and I get heat but after a mile or two the heater goes cold. Also my od is flashing on the dash. Thanks lee
    Aug 2011
    lincolnshire
    I'll check my wires but can't recall that wire that's probably the problem unless it's called something else on my paper work thanks
  8. #38
    Nov 2011
    if your od light is flashing means it's picked up an error code
    in the tranny side of things
    your alternator might be fkt
    if light goes out means its trying to charge
    u will measure 12 volts on all 3 alternator wires
    but one is the light so that gets earthed
    also have u wired up the thick wire from alternator to battery
    some uneducated home mechanics always forget this wire
  9. #39
    Aug 2011
    lincolnshire
    Lol I'm a home uneducated mechanic but I have been to proper mechanics around 80 miles radius and all of them have no clue of shores think there all fitters lol but with the help from wilbo it was sorted just shows England is way behind. Even the auto electricians had no clue umm any way it was the batt no good I did not join a fat wire from the alternator as all the wire join under passenger side glove box. Thanks for od reason I will diagnostic it soon. Thanks guys
  1. supra mkiv 1jzgte swap help needed
    By leeti in forum Tech and Conversions
    Last Post: 07-10-2011, 05:04 AM
  2. 1jzgte gearbox loom to match supra mkiv auto box
    Last Post: 28-09-2011, 11:33 PM
  3. new member supra mkiv 1jzgte
    By leeti in forum Toymods Car Club Membership and Feedback
    Last Post: 03-09-2011, 08:03 AM
  4. Replies: 15
    Last Post: 01-08-2011, 09:11 AM
