Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: supra mkiv 1jzgte swap help needed
    Aug 2011
    lincolnshire
    Default supra mkiv 1jzgte swap help needed
    hi is there anyone that could help with these wires. im trying to match the body plugs.
    these are the wires i have .
    ik1 yellow/black oil pressure gauge =pin 25 orange plug supra low oil pressure switch (output) or pin 33 low oil level switch (output)
    ik1 reverse light red/black = pin 36 orange plug reverse light and reverse gear auto tran indecator (output)
    ik1 water temp gauge yellow/green = pin24 orange plug dash water temp gauge ground.
    ik1 tacho black =pin29 tachometer output from ignitor
    ik1 blue/yellow engine light WARNING = pin15 engine ecu W check engine light
    ik1 speed sensor red/blue =
    ik1 at switch blue =
    ik1 VF diagnostic plug=
    1k1 green/red TT test plug=
    ik1 white L a/t indicator switch=
    ik1 green/orange p patern select switch=
    ik1 gray/red od2 o/drive switch=
    ik1 red/white igw=
    gray/yellow T=
    ik2 brown groud 4 fuel pump=
    ik2 black NSW=
    ik2 black/blue NSW=
    ik2 brown ground for clusters
    ik2 red/green S a/t indecator=
    ik2 green CCo
    ik2 light blue tems check connector=
    ij1 red/yellow ELS idle up external load input = pin 32 orange plug ELS elec load sense
    ij1 yellow/green engine light /battery light= pin 34 orange plug alternator L charge warning light output
    ij1 black natrural start switch=
    ij1 black/white starter=pin23 orange plug ignition switch power
    ij1 red/green FPC Fuel pump control =pin4 gray plug fpc control output
    ij1 pink SP speed =
    ij1 green fuel=
    ij1 black/red fuel main= i put direct to the batt
    ij2 black/white starter=
    ij2 red idl1 primary throttle tps
    ij2 pink D1 fuel pump control relay speed sensor= di fuel pump diagnosticc indecator
    ij2 brown/yellow fp control=
    ij2 green/white STP stop light switch=pin11 gray plug STP stop light switch input
    ij2 white/red S2 speed sensor=
    ij2 black/yellow 12v switch alt to charge=
    ij2 black switch power ignition
    ij2 green/black progressive steering + =
    ij2 green/black progressive steering - =
    yes im using the supra na gearbox for now till i no it will all work then probly later in the future probly go manual
    thanks
    lee
    May 2007
    Default Re: supra mkiv 1jzgte swap help needed
    search for supra in the "wiring thread for all vehicles" there is a good pinout of the orange plug and other related plugs in it...
    or probably checkout wilbos wiki as it probably has it all there also
    May 2007
    if you have an email address i can email you the pdf that has the pins all mapped out for you
    I'm sure I linked you to the JZA80 2JZGE wiring in the past?
    wilbo666 / 2JZ-GE JZA80 Supra
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2007
    lol yeah im sure you have... either way youve now linked him to it all...
    problem solved...
    again...
    Aug 2011
    lincolnshire
    yeah you did thanks wilbro. i have written them down and tried maching them to the 1jz plug wires.
    iv connected a few of them but im not sure. when i first started to do the wires i could get it running but because iv been trying to do the other wires i have forgot whitch wires start it . its proper boxed my head in 4 months now and there is no 1 round my area that can help me every garage i go in thay say wooow no idea.
    thanks lee
    Aug 2011
    lincolnshire
    well i have been to nearly every auto electricion in my area and the wiring thay recon is well over there head.
    dont no what to do now i am actually thinking of given my project up
    is there any last hope that anyone could guide me through it i dont mind paying for ur services. thanks again lee
    May 2007
    in order to help you without seeing what you have done i need to understand 100% what you have done already and how the car came to you etc etc
    i am guessing it is a naturally aspirated jza80 and you have removed the engine to replace it with a 1jz...
    i need to know exactly what the engine came from
    what gearbox you plan on running and where it came from
    what wiring you have touched/cut/removed/replaced
    what wiring came with the motor
    from there i can start to tell you wires to connect to get it running
    and then from there what wires to get various gauges etc working
    Aug 2011
    lincolnshire
    i got the car a while ago and the engine blew. it is a 1993 supra na .
    so i had o get a engine and the only 1 that came up was soarer 1jzgte and the car was a h reg1990.
    so i put the engine in and joined it to the supra na gearbox.
    and the plugs near the fuse box pluged straight in.
    with the engine i got the harness was uncut and the harness goes into the passanger side footwell i have cut the plugs off whitch i think are ik1,ik2,ij1,ij2.
    i connected the thick red and black wire to batt and the 2 black/orange to the black/orange on the gray plug on the supra plug. and black/white to black/white on the supra plug and connected the nsw black/white to supra black/white. last night and it struck up sounded abit up and down idleing if that makes any sense. im going to see if i can get a decent camara today and i will take sum photos and put them on.
    thanks for the reply lee
    May 2007
    so is it an auto or a manual?
    and what ecu are you using to run the show?
    Aug 2011
    lincolnshire
    its a supra auto box. and the ecu and ignitor came with 1jzgte.
    and my supra loom apart from the body plugs was scrapped to pay towards my 1jzgte but wish i never scrapped it now.
    so yeah the 1jz ecu and supra na auto box.
    Taken some pictures of what you have / where you are at yet?
    Wilbo's JZA80
    Wilbo's JZZ12
    Aug 2011
    lincolnshire
    heres my wires on passenger foot well
    [IMG][/IMG]
    Aug 2011
    lincolnshire
    And this is the engine in my mkiv.
    [IMG][/IMG]
    [IMG][/IMG]
    OK,
    I'll be honest, that looks hard / difficult.
    What happened to the JZZ30 engine loom plugs, the ones that should be in the passenger foot well?
    Wilbo's JZA80
    Wilbo's JZZ12
  1. new member supra mkiv 1jzgte
    By leeti in forum Toymods Car Club Membership and Feedback
    Last Post: 03-09-2011, 08:03 AM
  2. mkIII supra 1jzgte vvti motor swap questions
    By supradrew in forum Tech and Conversions
    Last Post: 28-01-2011, 01:00 AM
  3. FMIC ducting for a mkiv supra
    By natett in forum Tech and Conversions
    Last Post: 03-12-2010, 12:26 PM
