Results 16 to 24 of 24
Thread: More BOOST does NOT = more power 05 Rodeo 4JH1 TD
    Default Re: More BOOST does NOT = more power 05 Rodeo 4JH1 TD
    My first thought would be that its choked... something isnt flowing enough inlet or exhaust air.
    Did the dyno guys check for exhaust pressures?
    Act
    Nah I know Jake doesn't check exhaust pressures. I'll get some answers to all your questions thanks for the input guys.
    Oct 2008
    TAS
    Quote Originally Posted by fixeruperer View Post
    no they wont.
    Yes they will.
    1983 Toyota Celica Supra
    Oct 2009
    Quote Originally Posted by CELICASUPRA7M View Post
    Yes they will.
    No they wont
    A diesel wont run on straight petrol, older mechanical injection types will run on a decent mix but will be rough as all fuck. Some knob filled our 5L work hilux up with petrol and it came back on a tilt tray and would barely run, it was shaking, idling like shit, missed, revved like shit, blowing smoke. Until we were told it had been filled with vortex (the wrong type of vortex) we were thinking it had skipped a tooth on the timing belt or the pump had had a crisis.
    Act
    So I've got some answers.
    It has a Mech/Electronic fuel pump
    The dyno run was carried out with a pod filter just before the MAF sensor
    3” exhaust from turbo back, match ported with high flow cat (runs great otherwise)
    EGR has been checked, cleaned and operation is fine
    The Safari Dtronic chip is not tuneable
    The engine is Pre-common rail
    No exhaust pressures checked
    With the EGT, Boost gauges, controller and dyno run it has cost my mate less than $500, so it’s no big deal. He would like to get to the bottom of this, there must be a way to cheat the system...
    Another thing he has heard is that he should disconnect the EGR valve... Thoughts...
    He has also been told that the Fuel pump isn't adjustable.
    as matt said, what about the particulate filter ?, even just removing them, there is good gains.
    note they're there to remove very bad cancer causing particulates, so avoid having them running in enclosed spaces unless you have a chemotherapy fetish
    most diesels will run on petrol and most petrols will sort of run on diesels lol.
    depends how much money you have to replace the (hugely) expensive diesel fuel pumps. regular petrol <> diesel pump
    perth
    Quote Originally Posted by Draven View Post
    everything is cancerous.
    Oct 2008
    TAS
    The hilux we had at work had pure 91 octane petrol, it was nearly dry and the guy filled it to the brim and drove it all morning. after flushing the fuel system it was good as new.
    however a mates prado threw a rod out the block when it copped unleaded and it has the same motor so who knows haha
  1. 1JZ/2JZ into Holden Rodeo - realistic?
    By Archie in forum Tech and Conversions
    Last Post: 17-10-2010, 08:38 PM
  2. how to boost power to starter
    By warrior in forum FAQ
    Last Post: 01-03-2006, 05:49 PM
  3. how to boost power to starter
    By warrior in forum Tech and Conversions
    Last Post: 20-02-2006, 05:16 PM
