Results 1 to 15 of 24
Thread: More BOOST does NOT = more power 05 Rodeo 4JH1 TD
    Act
    Default More BOOST does NOT = more power 05 Rodeo 4JH1 TD
    Hi all just wanted to help a mate out, he has a 05 Rodeo with the 4JH1 TD in it
    Its got a 3 inch exhaust, aftermarket cooler and runs a Safari Dtronic piggy back chip.
    Now he went out and bought a Boost Controller, Gauge and EGT sensor with the aim of upping boost on the run to help with towing etc.
    This is the Dyno graph
    The top runs are with the chip installed lower runs aren't, dotted lines are boost.
    The reason for the question is the 3-5kw gain all that can be expected from the extra boost. My mate was hoping for a little more. The tuner was stumped he has never seen so little gains. Even on the turbo diesel. My mate used the tuner I used for the wagon and he is a smart cluey guy.
    Just looking for experiences of people that have played with Turbo Diesels
    thanks Stitt
    Jul 2007
    Default Re: More BOOST does NOT = more power 05 Rodeo 4JH1 TD
    are these electronic fuel injection? loz's landcruiser is mechanical and all we did was turn up the fuel metering screw and let it freeboost. makes shitloads more power lol
    not exactly the most technical help... but yeah
    Jan 2007
    queensland
    what was the torque increase?
    usually more fuel = more boost = more power from the deseisels i've seen... as this has a chip on it, and was tuned properly this should have been sorted... but yeh most of them seem to double in power (to equal a normal petrol engine) but make insane amounts of torque...
    was a hi-flow particulate filter used?
    perth
    ive only played with the common rail diesels, like the gl mercs, when i chipped them, they cheat the rail voltage and it ups the boost and pumps more fuel in, i never put them on the dyno but the seat dyno, was impressed, made a big difference.
    as matt said, what about the particulate filter ?, even just removing them, there is good gains.
    Forum Contributor Domestic Engineer
    Yeah, if the fuelling is not adjusted, then it might not increase in power at all.
    Also, there is a reasonable chance that the turbo may not be able to push more air either. I've seen a couple of factory TD's that after the basics were done, they just could not make any more power due to the small (factory responsive) turbo not supplying any more air as the boost was wound up. Once they changed to a slightly larger turbo, run at the same boost, power was increased.
    Check the fuelling as the first point though.
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    +1 on what the others have said. was it a plug in chip, or a tunable chip? as the others have said diesels dont increase power unless you put the fuel into it.
    also what the others said.. did the exhaust system include the cat.. or was it a cat back? these things are infamous for melting cats and restricting power. if you pull it off and find it buggered, replace/block the EGR valve assy also, as the blacked cat buggers these aswell.
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
    Oct 2008
    TAS
    yeah, ive seen a few rodeos that had blocked cats, also one that went back to the dealership over and over for no power. they couldn't fix it lol.
    My advice, get a ford ranger 3.0 td, they chirp 2nd on dry bitumen lol
    1983 Toyota Celica Supra
    May 2010
    TAS
    Diesels like to run lean and too make big power...massively lean.
    It's a different fuel chemically and needs to be treated differently in regards to air fuel ratios compared to petrol engines.
    Perhaps the tuner doesn't fully understand stoichiometric ratio's regarding these engines.
    Oct 2009
    Quote Originally Posted by dangdang View Post
    Its not really an issue to run a diesel engine lean, its part and parcel of controlling the fuel not the air. They are the complete opposite of petrol engines, run them too rich and they go pop
    Sounds to me like its not getting extra fuel for the added boost, being common rail means its an ECU issue and not a simple (but dodgy) method of having a fiddle with a mechanical injection pump to add more juice. Chances are the added boost is outside whatever parameter the ECU considers safe and wont come to the party, piggyback might be able to fix it.
    Most piggy back diesel chips are fairly simple, increase the rail pressure, more injection timing, more boost. None of it is great for engine longevity, especially when you start playing with more fuel and timing.
    perth
    hmmm, i never seen a drag/race diesel look like its running lean.. those things chuff like a mofo.
    Dangdang:
    Diesels don't make the most amount of power when running lean at all. No fuel means no power. They run smoothly and economically when running lean - up to around 35 and 40:1 is not that unusual for low load work.
    Stoic for diesels is around 14.5:1 - not all that different from petrols, and they will often make max power when running slightly rich. Problem is however, that soot is rediculous, and EGT's are hugely difficult to control. Drag type trucks will often run their AFR's down around here to try and extract every last pony out of the engine, kicking and screaming.
    Most normal diesels I've seen are tuned 'lean' to around 18 to 22:1 AFR as this seems to be the best compromise between reasonable power, good reliability, fuel consumption, low smoke and controllable EGT's.
    Oct 2009
    Quote Originally Posted by fixeruperer View Post
    That's because they don't have to last or meet emissions
    Do the same to your landcruiser and if you don't melt a piston or two first you will get pulled over for blowing more smoke than Thomas the tank.
    perth
    yeh but did you see how happy thomas was most of the time
    i thought we were talking about power anyway
    Oct 2008
    TAS
    most diesels will run on petrol and most petrols will sort of run on diesels lol.
    We had a current model hilux come into work lacking power, took it for a drive and it still got on boost ok, just a bit gutless, turned out it was full of unleaded lol.
    perth
    no they wont.
  1. 1JZ/2JZ into Holden Rodeo - realistic?
    By Archie in forum Tech and Conversions
    Last Post: 17-10-2010, 08:38 PM
  2. how to boost power to starter
    By warrior in forum FAQ
    Last Post: 01-03-2006, 05:49 PM
  3. how to boost power to starter
    By warrior in forum Tech and Conversions
    Last Post: 20-02-2006, 05:16 PM
