Results 16 to 25 of 25
Thread: 2azfe crank in 3sgte
    Junior Member Grease Monkey off-road's Avatar
    NT
    Default Re: 2azfe crank in 3sgte
    Quote Originally Posted by jimmy_a
    I'd hazard a guess that it doesn't.
    Being different engine series and the fact that the stroke on the 2az is longer id say youd have trouble and thats not even taking into account bearing sizes or the piston separation or anything.
    A crank out of a 4age will fit a 2zzge despite them being different series and the difference in stroke is the whole idea of using the 2az crank.
    Also for what its worth bigend and main journals are the same size .
    serial biochemist Automotive Encyclopaedia
    Quote Originally Posted by SeptemberSquall
    or if a ford 250 crank fits in a holden red motor... oh, hang on a minute... lolzor @ u!!!oneone
    it's a ford 221cui motor crank that goes in a 186 red motor. Strokes it out nicely.
    I've got one in my shed (complete 221 motor) if anyone wants it.
    jimmya Grease Monkey jimmy_a's Avatar
    Im starting to wonder if it might actually be possible. Are you going to try it?
    Quote Originally Posted by blacktopspirit
    Gastro has hurt me for 4 days now! want to die! to scared to fart, to scared to eat, to scared to be more than 4 meters away from toilet!!!
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Whats a 2azfe out of anyway?
    Ahhh the Camrys and Taragos. Fairly common then.
    NT
    I'll put an ad in the wanted section and see if i can get hold of one to try.
    Quote Originally Posted by Cool1
    Camry 4cyl models. New RAV4. Avensis. Tarago.
    May 2006
    ZZ cranks fit 4A's so it might be worth a look, but to be honest the 5S Rod ratio is bad enough as it is, let alone a 2.4L stroker...
    5SGE/GTE long rod info - http://www.evolutune.com/?id=4
    2JZ rods, F20C pistons and machining is the cheapest 3S stroker using the 5S crank if you want to improve the 5S piston slappers.
    Quote Originally Posted by off-road View Post
    As someone said earlier check the bore to bore spacing first. The S-series engines have uneven spacing so I would be surprised if anything else fits. The reason why a ZZ crank can be made to fit a A-series block is because both use a 87.5mm spacing.
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    Another thread from the dead
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
  1. bigport crank in a gze
    By AE101LEV in forum Tech and Conversions
    Last Post: 07-04-2006, 10:15 AM
  2. To 3sgte or not to 3sgte
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 23-03-2006, 04:23 PM
  3. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 06:55 AM
  4. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 03:03 PM
  5. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 08:15 PM
