Any custom fabrication - be it turbo or SC - will cost you twice your budget (or so it's been for me).
Given that you've got - potentially - a high compression engine that had a turbo optiopn, i'd suggest you take advantage of it:
-get a 2nd hand smallish ball-bearing turbo - small exhaust housing too get boost on early and nothing to crazy on the inlet side. $200-$400 - something common so when it breaks you just get another one.
-get exotics exhausts to make a manifold & dump pipe ($500-700) or see if you can source a factory 2tgte turbo manifold $??
-get a 2nd-hand 2tgue intake manifold $??
-get chinese-made FMIC off ebay and piping/clamps to fabricate connections to/from turbo and the intake. $400?
-get a 2nd hand microtech or haltech ecu & injectors to suit projected power output $500-1500?
setup the fuel supply (pump, swirl tank, EFI hoses, etc) $250-350?
-learn to wire the engine - if this diagram (the fuel side of my EFI setup from sensors back to ECU) doesn't frighten you, then you're half-way there:
cheers,
Charles.
   I still thinks its such a crazy-cool idea that would spin people out
