Results 1 to 5 of 5
Thread: 4age bigport timing issue
    Nov 2010
    victoria
    Default 4age bigport timing issue
    Car:ae86
    engine: 4age big port with tvis stock everything, bit of a mangled loom
    issue:
    timing retards itself while accelerating, everything has been set properly at tdc etc, if you shut off the engine the timing jumps out by about 30deg and the motor wont restart, you have to turn it twice for the timing to reset to where it should be then it starts fine, idles fine but when you rev the motor the timing retards itself heaps instead of advancing.
    things like dizzy ignitor and ecu are all fine and working, all bolts are tight on the cam gears and everything was set properly at tdc.
    any ideas? the car feels about as fast as a worn out 4ac
    Jun 2007
    Default Re: 4age bigport timing issue
    Have you checked the main crank pulley? The key may be worn and this may be "slipping". Check that the bolt is tightened.
    "bit of a mangled loom" - has the car always been like this or has it just started happening? if it has always been like this since you have purchased it, etc, then quite possibly the CAS may be wired incorrectly?
    just putting the idea out there.
    Bodgepro Mechanic Grease Monkey Ghetto-Spec .:bayka:.'s Avatar
    Hey mate. There are some others here who have more knowledge of the factory setup, but it sounds to me like the ECU is running in 'fault' mode and retarding timing, and/or you have a major sensor problem.
    The most important sensors that are critical for the ECU to run the engine properly are:
    1. CAS
    2. MAP/AFM
    Agree with RT40Corona4AGTE, check wiring of these two sensors as a minimum and/or replace them as a first step, but its sounding like its the CAS.
    Chiba
    You are shorting pins E1 and Te1 in the diagnostic connector when you set base timing?
  1. 3tgte rotor position*nd timing issue
    By buzzbomber85gt in forum Tech and Conversions
    Last Post: 06-03-2011, 01:45 AM
  2. Carby !!!1GFE Timing issue
    By Casino Kid in forum Tech and Conversions
    Last Post: 30-09-2010, 07:32 PM
  3. Timing issue on the 89 Toyota Corona 2lt ( ST171 )
    By bigbadbaz in forum Tech and Conversions
    Last Post: 09-05-2010, 01:31 PM
  4. Bigport 4AGZE Cold Start Issue and Flat Spot
    By sbyder in forum Tech and Conversions
    Last Post: 12-05-2008, 08:01 PM
  5. 7mge brian crower cams and ignition timing issue
    By amichie in forum Tech and Conversions
    Last Post: 29-10-2007, 10:54 AM
