Results 1 to 10 of 10
Thread: Carby !!!1GFE Timing issue
    Junior Member Grease Monkey Casino Kid's Avatar
    Default Carby !!!1GFE Timing issue
    I got a bit of a odd ball Q for you guys, Basicly im runing a 1988 1gfe on carbys, now it runs well but the timing isnt advancing.im still runing the ECU with everything pluged in except the injectors,now im thinking the ecu wont let it advance cuz its not geting a signal from the inj, could that be correct? like almost a "safe" mode?,is there anyway to get around this or do i need to get a full aftermarket ign system. any ideas would be great
    oh and i dont need post saying "why you trying to use carbys " hahah i did it becuse i wanted to, no other reason
    thanks guys
    1989 MX83 Cressida- stock 1JZGTE /king springs/jic's/17's/jzx81 front end.. 248.9rwhp
    1988 GX81 Chaser, stock..........
    2001 hilux-Street racer/Drifter/Track king/ Daily driver
    Default Re: Carby !!!1GFE Timing issue
    Is the ECU throwing any codes?
    Now I'm not sure what configuration the original 1gfe had in terms of MAP sensor or MAF sensor, however if either of them is not in line then the ecu will not advance or (not needed now) inject fuel correctly.
    MAF would have to be incorporated into the intake tract pre carby's post air filter. MAP would have to be in the intake manifold post carby's.
    Hope this helps...
    Jason
    rat finking double post...
    May 2006
    tas
    have you got the TPS connected to the throttle?
    as far as im aware this is the main point of reference for load and there for timing.
    guys have run M and W (or what ever) ignition systems with the normal dizzy and had fixed timing on 4ags but its much less then ideal.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    i hadnt even thought of checkin that will do tomoro
    its map and i hav that fited.
    sure do? i orig thought that was the problem so i riged it up but no change
    May 2006
    tas
    btw have you got any pics, or vids of this set-up?
    -JZX83 in the build
    <3 7M sludge pump
    ill start a members rides thread soon
    May 2006
    tas
    please do.
    and i want to hear some induction noise on this bad boy!
    -JZX83 in the build
    <3 7M sludge pump
    Tasmania
    For memory dissy is much the same as a GE so just do as was done to the GE I had in my old GX 10 Mark 2 Rona is use a 5ME dissy and ignitor which basically was cut down shaft to suit with the GE cog or ME unsure but should work for your application.
    Cheers Brett.
  1. Hilux Rn85 22R Carby ignition timing?
    By vanman in forum Tech and Conversions
    Last Post: 11-02-2009, 08:09 PM
  2. 2JZGTE VVTi Timing Belt Installation, Help needed!
    Last Post: 20-11-2008, 05:05 PM
  3. 18rc carby issue
    By Hash_ra23 in forum Tech and Conversions
    Last Post: 09-05-2007, 09:28 AM
  4. 18RGU Carby and Cam Questions (long winded and a few pics)
    By floppy in forum Tech and Conversions
    Last Post: 07-01-2007, 12:25 AM
  5. Timing on a 3SGE
    By WindeX in forum Tech and Conversions
    Last Post: 29-06-2006, 02:19 PM
