Results 1 to 10 of 10
Thread: 3tgte rotor position*nd timing issue
    Feb 2009
    Kansas
    Default 3tgte rotor position*nd timing issue
    did some searching to no real answer on the issue. I have a 3tgte in my 85 celica gt-s and I replaced the headgasket and when putting it back together I got it at tdc and cams both pointing up and am not sure where the rotor in the distributor is supposed to point since there are 2 contacts. firing order is correct. I just need to know which of the 2 contacts (closest to cap or closest to dizzy base) points to what and where it points. I assume it points at 1F but im not sure. also need to know what the oil capacity is. it has a larger finned pan and a fluidyne oil cooler and twin entry ct26. im assuming around 7qts and it was running amsoil 0w20 but it was leaking out of the old slug like crazy so any suggestions from personal experience would be awesome. finding answers here in the states with this motor is like pulling teeth. thanks everyone. -Ryan
    Mar 2008
    Default Re: 3tgte rotor position*nd timing issue
    Bumping this up as I'm interested to here answers also!
    Al
    '77 YAMAHA XT500 - Project
    The Drivers' Vault
    Feb 2009
    Kansas
    it's got me itching to get the thing running. hasnt ran in 2yrs. had to manuegel a 3tc headgasket to work and cork and rtv around the timing cover and got all of that done and installed rce injectors and everything and it just pops when i try to start it....i guess if i dont hear back this evening i'll trial and error it
    With the engine on top dead centre firing stroke (difficult to tell if it is firing stoke without looking at the cams so use trial and error) Both rotor contact should be pointing to piston 1 cap contacts i.e. 1R and 1F (noting they both fire at the same time).
    So
    1. put the engine on what you think is top dead centre firing stoke (note it may note be because you didn't look at the cams)
    2. place dizzy in the engine so that rotors line up with 1r and 1f and the adjustment bolt is in the middle of the adjustment slot. This may take a few goes untill you get good at it as the rotor rotate as you place it in.
    3. put all you coil and plugs on.
    4. The engine will either run or give you a massive back fire, if it dose nothing unbolt the dizzy bolt and rotate untill something happens, if nothing happens check you are getting spak from the coil, if getting spark form the coil go back to step 1.
    5. If you get a massive back fire you are 180deg out on the dizzy (360deg on the crank). put the engine on top dead centre and check rotor line up with cap 1r and 1f. If they line up rotate crank 360deg untill back on top dead centre remove dizzy and move onto step 2. If they don't line up don't rotate crank 360deg and move onto step 2.
    6. your engine should be running if the cams are installed correctly, put a timing light on and adjust the dizzy until the crank marks line up.
    Hope this helps
    Roger
    Feb 2009
    Kansas
    Quote Originally Posted by 3jcelica View Post
    So
    Hope this helps
    Roger
    2 thumbs up!! got it idling on its own. the cams i installed sure are lopey but it definitely put a smile on my face. thanks!
    Good to hear it is running, with larger cams, larger turbo etc you are going to need to adjust that air flow meter to get the right fueling, suggest you get a dyno tune to make sure you don't run lean.
    Roger
    Feb 2009
    Kansas
    Roger
    its running on megasquirt standalone with a map sensor and no afm
    Mar 2008
    Did you make your own maps or use someone else's for the MS?
    What modifications do you have? I have a few maps from members on here which might be of interest to you for starters?
    Al
    The Drivers' Vault
    buzzbomer85gt,
    my apologies, I assumed that you where using the original gear if you had the original dizzy. No that theres anything wrong with dizzy's they just get in the way.
    Ahh megasquirt pm me if you need starting maps
    Roger
    Feb 2009
    Kansas
    i have a few maps myself. pm sent
  1. Carby !!!1GFE Timing issue
    By Casino Kid in forum Tech and Conversions
    Last Post: 30-09-2010, 08:32 PM
  2. Timing issue on the 89 Toyota Corona 2lt ( ST171 )
    By bigbadbaz in forum Tech and Conversions
    Last Post: 09-05-2010, 02:31 PM
  3. Replies: 36
    Last Post: 11-05-2008, 12:12 PM
  4. 3TGTE Flatspot Issue
    By Daymoe in forum Tech and Conversions
    Last Post: 09-05-2007, 08:43 PM
