Results 16 to 24 of 24
Thread: 5VZ-FE gearbox opptions
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Default Re: 5VZ-FE gearbox opptions
    I have seen the build plates on RT142 Corona's at the wreckers, and the ones with the 2.4l engine showed a W58 /box on the manual versions.
    RA23
    1G-GZE
    Quote Originally Posted by ra23celica
    interesting were these IRS 2.4L models or live rears, I'll check mine on the weekend (live rear 2.4L efi manual).
    The 5 speed manual was only an option on the 2L carby models anyway.
    If in doubt power out
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Your logic is flawed. You're assuming the VZ and MZ series have the same bellhousing bolt pattern, which may not be the case.
    My logic isn't flawed. Im not assuming. Have a look at an MZ and VZ series block side by side...and tell me what you think
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    I don't happen to have an VZ or MZ blocks on me, perhaps you could enlighten us all with some photos?
    I should be able to get a photo of a 1mz in the next couple of days. We can compare it with one of the pictures in the rwd 3vz thread.
    Wierdo Pervert Grease Monkey fuzz!'s Avatar
    wtf? you're not carrying a few spare VZ/MZ engines?
    wierdo.
    3vz Block
    1mz Block
    They would appear to be different.
    Enjoy.
    ^ Transaxles that are used on the 3VZ bolt up and work on the 1MZ and vice versa...there are differences in the design (of course, different engine families) but they do work. So, i don't see why this adaptor plate wouldn't work with a 1MZ, going by simple bolt pattern and size. The only thing that may effect it could be the actual design of block...metal/brackets/bolts etc in the way.
    Kind Regards,
    Kurt.
    Quote Originally Posted by JetspeedCamry
    But that doesn't necessarily mean the bellhousing bolt patterns are the same, which is the relevant point in this discussion. The photos above suggest the bolt pattern is in fact quite different.
  1. Verifying a w58 gearbox
  2. Converting MR2 S54 Gearbox to suit FWD Application
    Last Post: 29-08-2008, 04:37 PM
  3. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
  4. 1JZ-GTE Gearbox help required.
    By CrezBez in forum Tech and Conversions
    Last Post: 23-01-2006, 09:06 PM
