Results 1 to 15 of 15
Thread: KTRL-25 spring rate
    Default KTRL-25 spring rate
    does anybody know the rate of these? wouldnt mind getting them for KTFL-76SL as well if possible
    had a google and cant find anything
    Never late in an x8
    Default Re: KTRL-25 spring rate
    Call Kings
    Seconded.. they are very good with that kind of information if you pick up the phone and call.
    Now - RA23-WRX
    Jan 2007
    queensland
    call or email..
    i usually have a response within a few hours.. alot easier to just call
    sweet will call them today thanks guys
    i was hoping to do the ole mix'n'match from the catalogue but no dimensions or specs in there :s
    Never late in an x8
    Jan 2007
    queensland
    yeh i've tried that many times
    there pretty open with their dimentions and rates etc.. if it helps at all, i have a handfull of dimentions that have been compiling for when i am after the exact same thing you never know what you might find... eg - BMW E30 spring - same as mitsubishi colt and N15 nissan pulsar...
    to convert LBS/" to KG/mm simply multiply the lbs/'' by .0179
    example below (springs for IS200)
    KTFL-90 - 340lb/" - 6.08kg/mm
    KTRL-91 - 235lb/" - 4.20kg/mm
    KDRL-65SP
    Spring rate - 230lb/"
    ID Top - 88mm
    ID Bottom - 67mm
    Free Height - 280mm
    KDFL-01
    Spring rate - 220lb/"
    ID Top - 115mm
    ID Bottom - 115mm
    Free Height - 270mm
    KDRL-50SL
    Spring rate - 130lb/"
    ID Top - 118
    ID Bottom - 118
    Free Height – 290
    KDRL-115
    Spring rate - 240lb/"
    ID Top - 115
    ID Bottom - 115
    Free Height – 280
    KDRL-65
    Spring rate - 210lb/"
    ID Top - 88
    ID Bottom - 78
    Free Height - 280
    KCFL-36GSR
    260mm FH
    140mm ID
    235 LBS/IN
    KCRL-214
    280mmFH
    77mm ID
    140-260 LBS/IN RED 67mm ONE END
    KCFL-42
    300mm FH
    150mm ID
    185 LB/IN
    KCRL-43
    340mm FH
    100mm ID
    100-190LB/IN RED 95MM ONE END
    Andrew, I believe that amichie found this info out originally when looking at other options as he felt the Kings were a bit soft.
    Code:
    Brand	F/R	PN	Kg/mm	Wire Dia	No of coils	Free length
    Lovells	F	TFS-51	3.29	16		5		310
    	R	TRS-52	4.11	15		8.5		365
    Kings	F	KTFL-76	2.67	16		5.6		310
    	R	KTRL-77	3.47	14		8		350
    nice one mattysshop, thanks.
    zop i saw amichies ones, but more after non-mx83 alternatives.
    spoke to a very helpful bloke at kings today, he said he cant give me the catalogue with dimensions, but is gonna have a look through it for me and see what else will fit (mainly for the front)
    KTRL-25 is 200lb for anyone interested (15lb over the KTRL-77 listed option for mx83)
    Never late in an x8
    just got this back from king, looks like no off the shelf option for better fronts.
    Hi Andrew
    The KTFL-76 is the only coil we do with 165mm id and a150mm reduction on one end.The only way we can do this for you we would have to make a custom coil,so will need to be more precise on the rate as you own it once it is made.
    The cost to custom make is approx $300 a pair plus freight so we need to get it correct.They will take around three weeks to make after payment .
    Regards,
    Ian Brown
    Sales and Technical Services
    KING SPRINGWORKS PTY LTD
    Never late in an x8
    Just get JZX81 coilovers dude.
    My Cressida drags its arse like a dog with worms if i have more than 2 people in the car. I reckon the Kings for the Cressida are comfortable but too soft for carrying any weight in the rear. *subscribed* to see if there's a good alternative.
    Simon.
    1991 Toyota Cressida (JZX83).
    yeah im not paying $300 for a pair of springs.
    if i can stiffen it up for cheap (got a buyer for my existing kings) then ill do it otherwise just leave as is til future suspension work. i have major front end work planned in which jzx81 coilovers would be redundant.
    Never late in an x8
    so i worked out a stiffer option for the front, will post some pics when ive finished the cutting and the welding and the drinking
    might call the kings bloke again and see if there is something stiffer than KTRL-25 that fits in the rear, they only work out to 3.5kg/mm. might be a bit mismatched. gotta work out the fronts but im guessing they are in the 8-12 range
    Never late in an x8
    Hi Andrew
    I have given up on KIngs, Lovells and k;mac etc. I have found an excellent spring maker who can make it to your specs or drawing at around half the price kings quoted you. He can also reset springs and make custom sway bars etc.
    so the KTRL25 is the stiffest available in that size.
    might throw it all together and see how it goes, maybe go custom springs in the back if its no good. your new swaybar did look nice though andrew.
    Never late in an x8
  1. Spring Rate to Damper Ratios???
    By Duk in forum Tech and Conversions
    Last Post: 01-02-2011, 04:28 PM
  2. ae82 spring rate
    By LO01UX in forum Tech and Conversions
    Last Post: 17-11-2009, 07:51 PM
  3. Spring rate selection (GA61) *HELP, NEED REAR SPRING RATE*
    By mullett in forum Tech and Conversions
    Last Post: 28-06-2009, 04:49 AM
