Results 1 to 3 of 3
Thread: Hilux - 1jzgte VVTI Radiator Options
    Apr 2011
    Default Hilux - 1jzgte VVTI Radiator Options
    Hi Guys,
    I am well into my conversion have everything sorted Fuel, Intercooler, Electrical which leaves me with the cooling.. I used the Bic Performance mounting kit which was for the 22R (i had 3y) a redrill on the left mount and a great fit.. I'm left with the motor very close to the firwall and 62mm from the front of water pump pulley to front panel..
    So what options work, have as to radiators - have the original Chaser, Soarer, Supra been used .. Have read alot of threads but none are radiator specific with types been used..
    Any help ?
    Newest of the Noobs
    Default Re: Hilux - 1jzgte VVTI Radiator Options
    I personally used a modified aluminium 86-96 Rodeo radiator for my 1JZGE VVTI conversion
    Jealousy is a curse
    Apr 2011
    Since i had it - i've now modified my hilux radiator by removing the mounting bracket and using the shroud mounts to secure it in doing this it's given me about 20mm clearance to the pullies. I also used the original chaser lower hose used a metal joiner (with temp sender so fixed temp guage problem) with the lower hilux hose to connect lower portion.. For the top modified the thermo housing and top hilux hose to suit..
    Newest of the Noobs
  1. 1jzgte vvti or non vvti
    By Axil in forum Tech and Conversions
    Last Post: 21-04-2011, 10:56 AM
  2. Twin turbo 1JZGTE or vvti single factory turbo 1JZGTE ???
    By matt_spitfire in forum Tech and Conversions
    Last Post: 30-03-2010, 10:48 PM
  3. AE111 20V Radiator and Cooling Upgrade Options
    By DreadAngel in forum Tech and Conversions
    Last Post: 29-03-2010, 05:13 PM
