Results 1 to 7 of 7
Thread: TA22 broken bonnet latch - HELP
    May 2009
    Default TA22 broken bonnet latch - HELP
    Got quite a problem... I bought a TA22 for a project car and she is know sitting up in the garage waiting patiently. Pretty big problem though - I can't open the bonnet.
    The previous owner stripped the engine bay to paint it, he got as far as painting it and then lost interest. So I went up the coast and put the engine back in and put the bonnet back on for transport. I heard the click and then thought "oh shit, what if old mate didn't reconnect the bonnet release cable..." Sure enough, go to pop the bonnet. nothing... engine is in the bay so there is very minimal room to get up from underneath.
    Current plan is either try and squeeze my arm up with a pair of pliers, use a screwdriver attached to a broom handle and try and get through from the front (the grill and radiator are all still off), or possibly get some cable or thick fishing line and feed it in from the back of the bonnet to try and release it.
    Anyone had a similar issue? If so how did you fix it? Anyone willing to go take a camera and post a photo of the bonnet release latch so I can try and figure out what I need to do?
    Doug
    Currently nursing a nice old celica back to good health
    Jan 2008
    queensland
    Default Re: TA22 broken bonnet latch - HELP
    if you dont have the grile and radiator in your made.
    stick your head in there and with a torch and flat screwdriver find the spot where the bonnet cable shoudl be and give it a shove
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Jan 2008
    queensland
    double post
    my bad
    2009 aurion
    liltdv8, that might be a bit difficult considering the latch is on the firewall.
    Melbourne, Victoria
    ...maybe see if you can undo the bonnet hinges from the front of the bonnet and then lift the bonnet enough to wedge in and release the catch....good luck
    - Jackie Stewart
    Junior Member Grease Monkey ta22fan's Avatar
    May 2008
    If you remove most of the front parts including headlight assemblies (all pretty easy tho) - you'll be able unbolt the bonnet hinges, and that'll get you sorted.
    Jan 2008
    queensland
    Quote Originally Posted by LeeRoy View Post
    well that would stuff up the day
    neil
    2009 aurion
  1. Broken bonnet latch
    By pr*duct in forum Tech and Conversions
    Last Post: 15-01-2007, 08:53 PM
