Results 1 to 10 of 10
Thread: 3sgte losing an abundance of oil
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    Default 3sgte losing an abundance of oil
    hey, so went for a drive up to rents, to do camber bolts for track day, when she started making a real sluggish feel up to boost, i checked behind and there was a fair bit of smoke, =/ i recently rebuilt the ct26, and ATS, put it back together.
    i got a compression tester, but on my journey to comp test it, i found no 2 and 3 cylinders above the spark plug were so full of oil upto the socket end..now its covered by a boot cover so nothing came into it, its leaking from some where in there, could this be the inner rocker cover section? also what could cause that much oil its literally liberally coated the rocker cover and noticably under the throttle body coupling
    edit: smokes at idle when cold but not at op temperature
    Current: 1990 ST185R Celica:
    http://www.toymods.org.au/forums/showthread.php?t=62315, DAEWOOOOO ESPERO
    Previous: Ta22 4aGZE; Older: 99' WRX Impreza 192kw
    Default Re: 3sgte losing an abundance of oil
    Rocker cover gasket for sure for the 2-3 cylinder
    Will cause a miss, and make is really sluggish.
    What colour smoke is it?
    27.90s @ Esses Hillclimb
    Apr 2008
    im definately thinking its that part of the gasket. because the opening was sealed by the lead boot, so the oil must have been pissing out into the cylinder, what im thinking is maybe the excess pressure from being pumped into it forced its way out onto the top of the cover somehow spraying oil?? the smoke looks grey but i havent reaqlly ever seen blue smoke before, or told the difference between black either. theres a **** load of black stuff sprayed out the exhaust on the ground behind the car though.. ill upload a video quickly. remember only smokes at idle when cold
    Aug 2009
    when i see these rocker cover gaskets leak the oil doesnt really make its way into the cylinder.. whats it breathing like if you remove the oil cap while its running?
    Apr 2008
    Quote Originally Posted by pandaah View Post
    haven't checked that :/ yeah but no 2 and 3 were completely filled with oil lol, and there was no way oil could get in around the spark plug boot, plus no 1 and 4 were fine dry
    Apr 2008
    That just looks like normal exhaust steam.
    The black stuff on the ground is just carbon that the steam picks up from the exhaust pipes.
    If it was oil smoking that much at idle, i would think it would be doing it more or less all the time.
    Apr 2008
    Hmm it puffs out smoke when you rev it though:/ and now when your driving there's so much oil being burnt in the engine bay that it comes into the cabin :/
    Quote Originally Posted by punkture View Post
    Ok, well what was in the video appeared steam.
    If its strong enough to smell in the cabin, surely itll be pretty easy to track down in the engine bay?
    Apr 2008
    not a good day =(
    By punkture at 2011-07-18
    which resulted in:
    i found both the shards, so they didnt enter the block, but the metal frgaments i think have done there damage, first dry test revealed:
    210, 210, 250, 90
    and wet
    270 270 270 150
  1. Losing Coolant
    By Razor in forum Tech and Conversions
    Last Post: 23-03-2009, 02:57 PM
  2. THE MA61 - Mysteriously Losing Engine OIL
    By fact0r in forum Tech and Conversions
    Last Post: 23-02-2009, 10:54 AM
  3. Car losing traction in wet a lot
    By Z2TT in forum Tech and Conversions
    Last Post: 30-09-2008, 12:27 AM
  4. argh!! 7M losing power under load
    By jimmmayyy in forum Tech and Conversions
    Last Post: 03-02-2008, 12:45 PM
