Results 46 to 55 of 55
Thread: T.c.c.a.v. Dyno day sunday 25/09/11 doctor drift tottenham
  1. #46
    Default Re: T.c.c.a.v. Dyno day sunday 25/09/11 doctor drift tottenham
    Quote Originally Posted by Celica RA45 View Post
    just wondering how this works, you made 155.1 kws and 395nm from you 2 jz turbo
    and my 3sge made 154.7 kws and 364 nm of torque go figure .i would have thought your turbo and being a 3 litre 6 would have higher torque figures and also my hp as well
    Keep in mind that your engine is not stock, had the internals played with and running a fully programmable ecu; compared to his stock engine with a cat back maybe an intercooler and boost controller....
    Lots of gains are to be made from the chaser with just a few bolt on parts, i was making 222kw with just a full exhaust, intercooler, pod filter, boost controller and piggyback fuel computer on a safe tune.
    Mr Shabadoo.
    Daily JZX100
  2. #47
    Forum Contributor Domestic Engineer
    Torque on a dyno can be misleading at best. I've compared dyno sheets from the same car, same (to my knowledge) correction factors, same dyno, but newly rebuilt vs old engine. The new engine made more power through every point of the RPM range, and yet the dyno calculated torque for the new engine was lower in some areas compared with the old engine. When HP = lb.ft * RPM / 5252, the amount of constants suggests that at a given RPM point, for more power to be made, more torque has to be made as well. Take the NM readings with a grain of salt.
    As for how a NA 2L, and a boosted 2.5L (effective displacement about 4.4L [ 2.5L x 1.75PR]) can make the same power I got NFI. Even with the 2L being hugely efficient and spinning some big RPM, and the 1JZ being fairly lazy and using tame RPM, it still doesn't work out in my mind.
  3. #48
    well yeah, power is a function of RPM, so effectively to make more power you need to make the more torque, or make it higher in the rev range. i assume the 3s had its peak figure a lot higher than the 1j.
    from what i understood, dyno's only measure torque (tractive effort really) and the power is then calculated with the above formula?
    Never late in an x8
  4. #49
    victroia
    keep in mind that this dyno was running no corrections on a reasonably warm day, bks car made about 15% les power on this dyno than it had previously on a dyno-dynamics
    also my bundy made 111kw on 33in mud terrains
    paul
  5. #50
    Junior Member 1st year Apprentice frankorbec's Avatar
    Feb 2009
    Hi guys. I don't want to muddy the waters here, but as everyone knows, different dynos give different figures. I recorded all KW results of attendants on the day, and although it seemed many of those who attended got lower KW readings than expected, we can compare vehicles tested on the same dyno on the same day quite fairly.
    Pozman's bundy proved very impressive with 111KW at the rear, and even a new ford G6E Turbo with 264.5 KW at the wheels was hugely impressive, considering new the motor is rated at 270KW. Most of the 1.6 to 2.0 litres ran between 45KW to 75KW in standard form, and some of the modified versions ran up to 108KW without forced induction (2003 Sportivo). If anyone wanted to confirm any figures, just message me, and i will send them through.
    Frank
    Ra28 Sleeper.
  6. #51
    Hi there Frank.
    I'm not questioning the actual power figures from the day. Mine was 8%ish down compared with other runs on another dyno - as accurate as I would expect from one dyno to another. My biggest issue is the AFR readings being very lean, and it seems I'm not the only one. No big deal though for me.
    Is there any chance of you posting up the results with all the runs so everyone can see how they did compared with similar cars?
  7. #52
    Feb 2009
    You are absolutely correct about the AFR figures. This just highlights the importance of calibration, and looking after your tools.
    (Yes, i am one of those guys where every tool has its place, and everything must be cleaned before it goes back, which is why i don't lend out tools.)
    I am happy to put up the figures tonight, just as soon as i get the little ones off to bed...
    Frank
    Ra28 Sleeper.
  8. #53
    Feb 2009
    Dyno Day results TCCA 2011.
    1 Ross 1989 A31 147KW
    2 Terry 1975 TA22 52KW
    3 Con 2000 Corolla 60KW
    4 Ross G 2004 BA 181KW
    5 Adam 1976 TA23 43KW
    6 Brendan 1976 TA23 45KW
    7 Lee 1989 MA71 230KW
    8 Omar 1995 Soarer 146KW
    9 Paul 1985 Bundy 111KW
    10 Glen 1979 RA45 154KW
    11 Pete 1976 KE35 60KW
    12 Dave 1973 TE27 71KW
    13 Darren 1974 KE30 12A 99KW
    14 Trung Chaser 155KW
    15 Tom 1994 CD5 75KW
    16 Philip 1997 AE111 82KW
    17 Tim 2003 Sportivo 107.9KW
    18 Chris 1989 AE 93 61.9KW
    19 Sean 1993 Civic 96KW
    20 Rob 1986 Celica 82KW
    21 Matthew 1986 AE82 54.6KW
    22 Andy 1989 AE92 64.6KW
    23 Cancelled Car
    24 Will 1990 300ZX 116KW
    25 Chris 1992 Cressida 209KW
    26 Joey R32 GTR 257KW
    27 Tim 1977 RA28 137.5KW
    28 Pete 2007 Swift 63KW
    29 John 1997 Chaser 219KW
    30 Mahil 1998 Chaser 171KW
    31 Oscar 1973 TA22 48KW
    32 Adam 1998 Chaser 171KW
    33 Sang 2011 F6E Turbo 264.5KW
    34 Pete 1985 Skyline 65KW
    35 James 1983 KE70 25.3KW
    36 Rowell 2003 Sportivo 102KW
    37 Chris 93 Commodore 93KW
    38 Andrew 1999 S15 169KW
    39 Ben 1979 KE70 27KW
    I hope settles some discussions...and start up some new ones!!
    Over 4300 KW of power rolled on the day. Some very impressive results.
    Frank
    Ra28 Sleeper.
  9. #54
    Melbourne Victoria
    hi frank my ra45 was na with a 3sge glenn spec motor
  10. #55
    Given the readings seemed to be a bit low across the board, I was quite happy with ~140kw at only 7psi.
    It was a nice close workshop for me, so I might take it back to him to tune when I get a programmable ECU and can wind up the boost.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  1. CCG Dyno Day 8 - Sunday 15 February 2009
    By jezz in forum ACT Events
    Last Post: 18-02-2009, 05:27 PM
  2. Toymods Dyno Day 17 - Sunday, 13th July
    Last Post: 04-08-2008, 08:01 PM
  3. Replies: 9
    Last Post: 18-10-2007, 09:29 PM
  4. Toymods Dyno Day 15 - Sunday, July 15th
    Last Post: 24-07-2007, 10:32 AM
  5. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 12:32 PM
