Results 1 to 5 of 5
Thread: 5mge lifters
    Feb 2008
    New South Wales
    Default 5mge lifters
    So Ive taken the head off to replace the valve steam seals and after doing some reading about why my motor was so noisy it seems the lifters might be the culprit. re - (http://www.toyotanation.com/forum/sh...d.php?t=354650)
    now I was wondering how you can tell if a lifter needs to be replaced (yes i know i should replace them all but this is my daily and im trying to save) a number of them when i pulled them out basically just fell apart (the little hat bit that holds the nipple in just slipped off) does this mean its needs to be replaced? I can put the lifter in a clamp and compress it down and slide the hat back on and while it does hold it in place should i not do this?
    Default Re: 5mge lifters
    This TSRM suggests that the 'bleed lash adjustor' does not come apart.
    http://www.cygnusx1.net/Supra/Librar...aspx?S=EM&P=32
    I think you'll have to replace any that fall apart - they're basically a leaky piston so if the top comes off you'll have zero gap between cam & follower/valve.
    I guess you could re-assemble them and try to crimp the outer lip back over the 'hat' - depends how ghetto you want to get
    Feb 2008
    New South Wales
    haha yer maybe not go that ghetto - if im replacing the lifters do i need to change the rocker arms as well i tried reading the trsm but it doesn't mention anything about it.
    You'd only change the arms if they've got excessive wear at the obvious spots on them. Unlikely to wear up at the pivot point but if the gaps has got huge (courtesy of the failed bleed lash adjustors), the cam might have have worn gouges in them. If they look OK, re-use them.
    Most of the noise is caused by a poorly working pressure regulator (thing in the middle of the head valley at the front).
    Pull it off, pull it apart, and clean it out.
  1. 3t roller lifters
    By danielc in forum Tech and Conversions
    Last Post: 14-09-2013, 05:22 PM
  2. 5MGE Gen1 Engine + 5ME Loom + 5MGE ECU
    Last Post: 02-03-2011, 04:13 PM
  3. need new lifters for 1ggte
    By frk5how in forum Tech and Conversions
    Last Post: 06-12-2006, 12:32 AM
  4. 4age lifters...all the same?
    By slide86 in forum Tech and Conversions
    Last Post: 07-03-2006, 11:18 PM
