 Re: Hydraulic press
 Re: Hydraulic press
				Not sure about FWD wheel bearings, however my 6T unit had no problems the other weekend putting together a 9" centre.
 Re: Hydraulic press
 Re: Hydraulic press
				 Re: Hydraulic press
 Re: Hydraulic press
				I'll have to check my press but I did my FWD corrolla wheel bearings easily, and this is just a supercheap hydraulic press.
 Re: Hydraulic press
 Re: Hydraulic press
				Hare & Forbes have a 20 tonne floor standing press for $230, $350 gets you a 20 tonne press with a gauge and removable hydraulic ram and pump (for other uses).
				 Re: Hydraulic press
 Re: Hydraulic press
				I have a 6T press, that I bought off ebay for about $70 and picked up locally. Its definitely a bit rough, and the channel section making up the frame is slightly bowed so it doesn't adjust the working height easily, but for the few times I use it its not an issue.
Have done AE92 front bearings with it. Force required was 'mild', so I reckon with some really stiff ones it'll still handle it, but only just.
So for occassional home use 6T will do the job, but if you're gonna be doing them often I'd step up to a 10T.
 Re: Hydraulic press
 Re: Hydraulic press
				Ok so I checked and mine is a 12t press.
