Results 16 to 21 of 21
Thread: Hydraulic press
    Default Re: Hydraulic press
    Not sure about FWD wheel bearings, however my 6T unit had no problems the other weekend putting together a 9" centre.
    Chiba
    Quote Originally Posted by Dale View Post
    Would a 6T be able to do FWD wheel bearings? Or would I need bigger?
    Also interested in this. I need something smallish that will do FWD bearings
    I'll have to check my press but I did my FWD corrolla wheel bearings easily, and this is just a supercheap hydraulic press.
    Chiba
    Hare & Forbes have a 20 tonne floor standing press for $230, $350 gets you a 20 tonne press with a gauge and removable hydraulic ram and pump (for other uses).
    Aug 2010
    I have a 6T press, that I bought off ebay for about $70 and picked up locally. Its definitely a bit rough, and the channel section making up the frame is slightly bowed so it doesn't adjust the working height easily, but for the few times I use it its not an issue.
    Have done AE92 front bearings with it. Force required was 'mild', so I reckon with some really stiff ones it'll still handle it, but only just.
    So for occassional home use 6T will do the job, but if you're gonna be doing them often I'd step up to a 10T.
    Ok so I checked and mine is a 12t press.
  1. 1JZ and 1JZ-GTE press kit
    By 3sgte in forum Tech and Conversions
    Last Post: 21-10-2008, 12:04 AM
  2. Hydraulic Press
    By TooF in forum Tech and Conversions
    Last Post: 05-05-2006, 03:37 PM
